What I have made is a composite saddle based heavily on the Dagger pedestal. I've stolen, tweeeked and updated the Dagger design to fit modern creekboats better. I will soon see how it fits in a playboat.
I have built a mold, and will be making another small batch in the near future. This one is a s-glass layup. The next versions will be vacuum bagged carbon fiber/s-glass and should be very pretty and light.
Those of you that use a Dagger know the benefits of quick and easy boat set-up and never having to shape foam again once you get it dialed. Problem is those things are getting to be quite rare now adays...
Some of the improvements over the Dagger saddle:
1. Extra length to engage the rear pillar better.
2. Narrower saddle base. This is important to me because I do a lot of multi-day trips and this will make it easier to get the gear bags in and out. Also, I'm not a fan of a big fat saddle because I want my feet to come out easy and I really don't think a wide sadddle is more comfortable (i ride bicycles and find those saddles comfy). But hey, if you want fat you can put in on there.
3. Multiple knee and thigh strap anchor points that are threaded. Super easy set-up and quick adjustment...No more fishing for nuts! All you need is a phillips screwdriver to move straps.
4. Contoured in rocker and profile to fit the hull better than, say, a fence rail.
5. Can easily be set up for a one pull system.
6. Last but not least...It's available!
Check it out while I go try to break it.
nevermind the color...
