Bliss-stick RAD 185 C1 $175 obo
Outfitted with dashboard type bulkhead and velcro lap belt. Currently leaks thru a 1.5" long split in the vertical part of the cockpit combing, looks weldable though. I also had to rig some gaskets to stop leakage at the screw holes around the cockpit. Sounds great, huh? The main hull is in pretty good shape, I'll send some pics if you're interested! Boat is in SW Va (near Bristol), i'll drive 50 miles to meet.
