Looking for gunwales for a dagger Impulse
greybear
Post by greybear »
I have a dagger impulse hull but no gunwales. Looking for either vinyl or wood or anything similar length would work.
rivercowboy
Re: Looking for gunwales for a dagger Impulse
Post by rivercowboy »
Mad River used to sell replacement gunwales for canoes in both wood and vinyl.
http://www.madrivercanoe.com/dealer_locator/" onclick="window.open(this.href);return false;
Check for a dealer in your local area and contact them.
Mohawk used to see vinyl gunwales also. You might want to give them a call and see if you can purchase a set.
mohawkcanoes.com
All you need to know is the length, estimate longer than you need since you won't want to stretch them.
I made some from sassafras that we got from a sawmill and planed down to fit the boat. They are beautiful.
Good luck!
Charlie Wilkerson
ACA Certified Whitewater Canoe Instructor
Dickson, TN
Suggest you take a look at Ed's sectional ash gunwale system.
http://www.edscanoe.com/14kndogusy.html" onclick="window.open(this.href);return false;
cramersec
Post by cramersec »
I went to a cabinet shop and asked them to cut me 4 1"x1" pieces of ash 14' long. Then I used a router to round the upper outer edge. This was for a glass Edge. Worked fine, and not very expensive.
Steve
Silent Bob
Post by Silent Bob »
If you can't find long boards, joining shorter ones with a scarf joint will be plenty strong. That part of the world, there's bound to be a little cabinet shop that could rip a few 3/4 x 3/4 strips for you.
-Bob
