$450 FOR SALE Red Dagger Ovation OC1 Open Canoe Solo-Denver
bogdandumitrescu
Post by bogdandumitrescu »
$450 FOR SALE Red Dagger Ovation OC1 Open Canoe Solo ( Denver, CO)
* excellent condition
* Has a nice foam saddle
* Has knee straps
* Has reinforced fiberglass bottom
* Included 2 floatation bags ( kept in a climate controlled storage, but i can't guarantee they 100% ok, but they should be easy to fix)
* Included 1 paddle
* You can also ship this thru a truck freighting company ... i did that when i bought the canoe
Below are manufacturer's specs.
Length: 11' 2" (3m 41cm)
Beam: 29" / 27" (74 / 69cm)
Weight (vinyl / wood): 39lbs (17.7kg) / wood not available
Depth (cnt / end): 15.5" / 16" (39 / 41cm)
Rocker (bow / stern): 5" / 5" (13cm / 13cm)6"
Free Board: 500lbs (227kg)
Perfect for the first-timer or the weathered vet, the Ovation is the best-selling all-around whitewater canoe ( or used to be till they stopped making it)
The forgiving asymmetric hull maximizes efficiency and minimizes surprises and the "ghost chine" at midship adds carving performance without edginess.
Shallow is good when you're talking about a shallow arch hull with outstanding initial and secondary stability.
And you'll enjoy staying dry with the highly flared ends.
Selectively reinforced Royalex® construction means durability like you wouldn't believe.
Deadwood
Re: $450 FOR SALE Red Dagger Ovation OC1 Open Canoe Solo-Den
Post by Deadwood »
How can we contact you?
coloradopaddler
Post by coloradopaddler »
would you be interested in a trade?
dollar
Post by dollar »
If its still for sale I'll be thru Denver later this month and buy it
post back or email meii@bessi.net
