Esquif blast. Ontario
I was in talks with a guy from Quebec about an esquif blast. I was set on buying it but was unable to arrange a way to transport it to Peterborough ontario ( my home). While I was waiting I did more research on the boat. I found that due to my size and the size of most people I would be paddling tandem with that it is not the boat for me. However the guy on the other end did a lot of leg work and found a person who will be driving from north eastern Quebec to Peterborough several times in October. So if you are interested in an esquif blast with tandem bulkhead outfitting I can contact the seller and have him deliver to Peterborough in October. I make semi frequent trips down to Guelph area and Sarnia area. He is asking $1100 plus the gas money to Peterborough. I have pictures I can send you if you pm me your email address. I can also put you in contact with the seller himself.
