ignore post, found what I was looking for
Wodza
Post by Wodza »
I'm looking for a XL slalom C1. I'm looking to buy sometime in the spring or early summer. Would like it to be a somewhat current design. I figured I would get a start in the search since it sounds like its going to be hard to find one in my weight range. I currently weigh 205lbs but can range between 190-210. If you have one or know of someone who does or have any suggestions as to where I should look. email me at ryan_wodham@hotmail.com.
Located anywhere in the USA or Canada works for me. I'll make it work.
With the Canadian $ below 70cents US I just can't come close to affording a brand new one.
Roy
Re: Starting to look for a XL slalom C1
Post by Roy »
Good luck with that. Ha.
I expect you have seen this:
https://www.cboats.net/cforum3/viewtopi ... &t=7969332" onclick="window.open(this.href);return false;
In addition to a shortened Zealot, I would suggest a shortened Dynamic or shortened Super-D. Kaz will build you a surprisingly cheap-for-new Super-D.
http://www.millbrookboats.com/c1cruise.htm" onclick="window.open(this.href);return false;
This is an interesting read for heavy slalom paddlers:
https://www.cboats.net/cforum3/viewtopi ... &t=7969106" onclick="window.open(this.href);return false;
Roy
