Posting as a guest (Sir Adam)
Guest
Post by Guest »
Greetings, all
Assuming this works as it should (and it did if you're reading this) you can still all post as a guest...BUT you have to use a "username" that IS BLANK. I'll try and clarify this in the Adamin posting.
If there is anyone out there that has had a problem "Registering" (link in the upper right-first you register, then you can log in upon future visits to the CForum, and see what posts you haven't read, what is new, etc...), let me know and I'll get you all set up (create a username of your choice (other than "Guest" :wink: ), and password of your choice (you can always change it as well).
To contact me: info@cboats.net (here comes more spam my way! I'm amazed at how much I get at this address, realizing the ONLY place that e-mail is used is on this site!)
P.S. I'm looking into other options as well here-I'm hoping to have it set up soon that folks can post normally as guests with usernames, but you may have to enter in a code on the screen to do so (to stop electronic posting from sites of ill repute that Scott and I are getting tired of deleting...).
