I don't know where to get it without the skin, but you can buy it with the skin in those dimensions from Davey and Jennifer Hearn at Sweet Composites. I bought a full bun from them earlier this year for outfitting my C-1. I think the dimensions you are describing are a "half bun" as a full bun is "4'X4'X3".
Unfortunately removing the skin was the most tedious part of working with that minicell. It's a pain in the neck to try to remove it enough to prepare it for gluing.
Remove it for gluing? Never bothered to do more than rough it up a little and never had a problem - I've got several pedestals built from scratch that have been in service for years with skin-on minicell glued together. Now for where it will be in contact with *me*, I do take it off. Usually in the process of shaping it (rasp, sureform, etc) or cutting it.
Nate, I have bought it from Davey & Jennifer many times. I just don't want to have to deal w/ the skin
SBroam, thanks! I just got the photo last night. Can't wait to actually get the boat
mshelton, that's close enough. If I can get up early enough, I may ride to Richmond before work tomorrow. Or, I could wait till next weekend & combine it w/ paddling the James
kayakoutfitting.com sells skinless - I just rec'd an order of a couple sheets for the Atom / Fink outfitting. Which are in progress.
I also use a sander - belt with med grit to rough it up. Takes only a few seconds and you get a good bond - just make sure you have a bag on the sander or you have to explain the grey dust to the family!
Oh by the way that is a strange looking hat that fella in the photo has on!!! It might not be flaked but its still pretty cool looking!
PAC wrote:that is a strange looking hat that fella in the photo has on!!! It might not be flaked but its still pretty cool looking!
It is a mighty strange looking hat. I think those Northern winters effect folks Next thing you know they'll be climbing ice If you save the photo & blow it up you will find some flake I think my boat's so bright, I may have to wear shades
so now this black minicell, I am accustomed to the grey minicell, is there any difference, some of this feels softer, but does it have the same resiliency? the stuff in the photo on the kayakoutfitting page is the stuff our local shop just got in, does this stuff last as well as the grey stufff?
thanks
-isaac
Isaac, regarding your question, apparently there is "L-200" and "M-200" minicell. Apparently they have the same density, but the L200 is softer than the M-200. On the Sweet Composites website it says the L is what is usually used for saddles, kneepads, walls, etc. in composite boats, but the M is slightly stiffer, and used more in roto-molded kayaks. Perhaps the stuff you refer to as being "softer" is the L, and you were accustomed to the M?
