twintex hulls and carbon paddle shafts
Since the handle is already on, it's probably too late now, but I use electrical heat-shrink tubing on my shafts (similar to what's on the Galasport shaft). I notice that McMaster Carr also now has shrinkable fabric sleeves now too. I'll have to order some to see how it works... Maybe a double layer.
OK Thanks, This has given me a lot to think about. I guess it's obvious that the Twintex is pretty abrasive stuff, and that I need to adjust my technique. I also think putting tape or shrink wrap on the shaft is a good idea. After looking at the exact place of wear and holding it next to the hull I'm realizing it's a stern pry hot spot. Especially while surfing I think. Rotating the paddle shaft from the stationary pry to stationary draw position while allowing too much contact with the hull (using it as a lever) is exactally what's causing it. Thanks again for all the input, it's good to have a place like this to ask a question, cause there's always something new to figure out.
Jim
Jim
