breakdown paddle recs
Need reccomendations on a breakdown paddle that will fit inside a Taureau. Seems like I'm better at swimming than paddling, so I need a backup paddle just in case. . . . .
Kim
Kim
Hand paddles? Ever try them? I've used them in a C-1 and they sure beat having no paddle at all and I can roll almost as well as with a paddle... I never tried them in an OC-1, but, well, we are talking about a Taureau
Maybe make/buy some that are 3-4" longer than what a kayaker would use?
Get a 3-piece breakdown paddle. It will fit any boat, I can stick mine even into my short playboats.
I have an aquabound, I had to use it once so far, it worked well in class 3-4 water.
Aquabound?
Might any of you have the link or phone contact for this aquabound 3-piece? All I see are yakker paddles whe I google it.
Thanks!
Thanks!
Aquabound 3 piece
Aquabound quoted me $110 US for the fiberglass handled Edge paddle plus 10 for shipping to Milwaukee back in April. I am still looking for something cheaper. For most of WI paddling you can usually hang on to your paddle.
This guy -
craiglangford@aquabound.com
should be able to help.
I wonder if we bought a bunch, if they would cost less.
I know the paddle fits in the Taureau easily
jc
This guy -
jc
You could just make a break down yourself. Wildwasser (prijon) sells ferrule kits (breakdown), or they used to anyway, they are used for making kayak paddles 2 piece, don't see why they wouldn't work for C paddles. you just need to know the diameter of the shaft. Would certainly be cheaper if you have an old stick sittin around, all you need is epoxy and a saw.
Good Luck
B
Good Luck
B
Galasport breakdown
Did you pick that up off their website or from a dealer.
Agreed about the price
jc
jc
breakdown
In 30 + years I've needed it twice. I have an rafting paddle that I snagged on a a trip, sawed it in half. I then fitted a piece of dowel for a spllint and carry it in the boat at all times. Yearly I replace the wrap of duct tape just to keep it fresh. Same idea works for spare ski pool on a pack int he BC.
C-ing is believing!
I've needed mine at least 6 times. I never go creeking without it.
I use a Lightning but it's heavy and I think they went belly up.
If your going to carry it a lot, don't get a super cheap (HEAVY) one. A light/ strong paddle like a Bandit is perfect. I have never seen the Aquabound, but it seems good as well.
Probably any manufacturer will make one for you if you can get ahold of an actual person.
And I agree w/Martin.. go for a 3 piece.
Also, take care to keep it protected in the boat. If it's rubbing on the hull it will get ruined pretty quick.
Let us know what you end up with!
