QR thigh strap anchor
I prototyped a quick release thigh strap anchor yesterday - it's based on a "pin an ring" (not unlike the Brown Pack System straps). I tested it with a single set of straps but think it would support a double. I'm using a piece of tubing for the "pin" but think something stiffer (perhaps an insert) is in order because it collapsed when tested under load (but still came out).
http://picasaweb.google.com/scott.broam ... 6293783106
I think I'm going to try to work it into an upcoming conversion...
gumpy
Post by gumpy »
and the pin could easily be attached to the skirt, for a one-pull release
Joe
cheajack
Post by cheajack »
Maybe the pin and spring loaded lever from some WWII surplus hand grenades would work.
5 second timer, too?
philcanoe
Post by philcanoe »
And rig it all to an airbag ejection seat....
http://www.youtube.com/watch?v=gLWVAidsXsU
(you might push the all button second time through!)
markzak
Post by markzak »
I like it! They make quick release buckles for surfboard leashes:
http://www.essentialsurf.com/ikorb.php? ... uct_id=171
eddyhops
Post by eddyhops »
JD
Mission
Post by Mission »
Yep I've been using one of these for a few months now (Since my airplane seatbelts failed) and it seems to work pretty good!
Pix of your install? I've looked at those before, too. My ideal solution would accomodate a double strap set up and let all go at once. Haven't tested mine with a double yet.
Mission
Post by Mission »
Yea ill post it up in the morning once i get to my boat.
It's a single snap shackle, the straps have 2 stainless D-rings and they both just go into the same snap shackle, which is connected to the cockpit rim by a length of para-cord.
Post by Larry Horne »
How did your airplane seatbelts fail? and what (brand) were they?
Mission
Post by Mission »
It turns out it was a chinese copy of an Amsafe buckle NOT a genuine Amsafe which probably didn't help.
The little spring in the middle corroded away on one, meaning it wouldnt properly open or close.
On the other one(the real worrying failure) the lever part somehow corroded and then bent out of shape so it was no longer engaging with the little bit in the middle, the belt would close but would not open once closed!
It's not as if they were not looked after, they were regularly washed and greased up so it wasnt just negligence on my part unfortunately.
TheKrikkitWars
Post by TheKrikkitWars »
Mission wrote:Yea ill post it up in the morning once i get to my boat.
This could be a solution soon to be implimented in my new creekboat, as I quite fancy having a 1-Pull release.
In fact what would be ideal would be if I could route a secondary release cord to the rear of the cockpit to go with a rear deck release (as per the rasdex creeking decks*, and the modification I've made to my IR SuperBungee)
*See the top left of this image.
Mission
Post by Mission »
Apologies for the delay in posting this.
Plus the failed airplane seatbelt
