What type of weight is it designed for,and does it make good creek boat.I have a Nitro,which is fine but pretty heavy and a little slow.I like the hull for surfing and would like to have the smaller version.I'm 200 lbs and 6ft.
Considering the Taureau,but i think the Detonator is a little better play boat,maybe i should condider the Spanish Fly,good creeker and play boat.
weight range of the Detonator
- sdbrassfield
- Supporting Paddler
I am 6'1 and 210 and although never owned a detonator have had 3 or 4 runs / play sessions in one of my buddys. It is a fun play boat and surfs well. I had alot of fun using it (when I was even heftier).
If you are looking for speed this is not your boat...It will definitely be slower than your nitro. If you do alot of creekier runs, I would get the fly. If you are wanting a play boat, I would get the fly. Fly will be more fun in the play spots and not rx, which will last longer for the creekier stuff.
SYOTR
