Neck rash
ELGOTTO
Neck rash
Post by ELGOTTO »
I love my Kokatat drysuit but that neck gasket tears me up. I stretch the neck out with a large sauce pan a couple days before wearing but it still rubs like crazy. What do you guys do to help this situation?
Craig Smerda
L'Edge Designer
Post by Craig Smerda »
stop shaving :lol:
Lappie
Post by Lappie »
Do you have any allergy to Latex?? If yes, I don't think there is a lot you can do!?!
fleckbass
Neck Gasket
Post by fleckbass »
I've stretched mine for 2 weeks on a cookie jar a bit bigger than my neck, paddled with it and stretched it again. 303 will also soften it up a bit.
I went raftin' once. I think it was in Ohio.
http://www.easternpaddling.com
markzak
Post by markzak »
try pulling the gasket down on your neck closer to your collar bone. Thats what I do and it seems to help. It should still seal properly. You can also, as a last resort, trim the gasket down from the top, a little at a time, until it fits better. But once you cut, you can't go back.
ELGOTTO
Post by ELGOTTO »
No allergies. I don't shave that low on my neck and I would call it something liked chapped lips except it's on the neck. Maybe I can stretch it some more and solve some of the problem.
Post by Shep »
Rub some baby powder or talc on the inside of the neck gasket each time before you go paddling. It'll at least help until you get wet.
Jim P
Trim
Post by Jim P »
I have always trimmed mine to get comfortable. Very careful, one ring at a time, brand new razor with the gasket lightly stretched out on a coffee can. I try for one continuous cut around the can.
Try it on, cut another ring if you still turn blue. You can always fill up a tub of water and test for water tightness. A drop or two leaking by when submerged is fine. A few drops of wet won't kill ya.
As long as you make a clean cut the gaskets will last a long time. I've had some last 5+ years. If you leave a ragged edge, it won't last long.
IMHO stretching the crap out of the latex will stress it out and result in premature failure.
303 several times a year will help as will a rinse of the inside of the gasket after each use to remove body oils. Sunscreen is also a bad idea.
Post by Larry Horne »
i bet it's some kind of allergy. a gasket that's too tight will just strangle you!
try the talc. it works for one guy I know..
303 makes it slick so that might help too.
D-Caption
Anti Chaff
Post by D-Caption »
Elgotto, Try a product called Body Glide... found at Hibbette Sports.They sell stuff for athletes. The most wonderful product i have ever used.
D-Caption Hope this helps
ELGOTTO
Post by ELGOTTO »
Thanks for the help. I'll try the powders first then if that doesn't work I will consider cutting the gasket.
Post by Shep »
Now that Body Glide has been mentioned, I think it's a great suggestion. It should last longer than the talc too.
ohioboater
KY
Post by ohioboater »
KY works to prevent the rash and does not harm the latex gasket. Of course, you need to be secure enough to be seen carrying a tube of that stuff in your boating tub/bag.
Same principle as the talcum powder, I'm pretty sure - dry latex grips your skin too well, and the hair follicles get all tweaked from the gasket pulling the skin every time you move your head. Talc or KY both make the gasket slide without compromising the seal.
And I'll echo the trimming recommendation for initial comfort and durability. That's why the gasket has those rings molded into it in the first place - they're trimming guides.
