Minicell foam
Minicell foam
Hey, does anyone know where to buy minicell foam in Canada for cheap? Thanks
foam
Try All-Foam in Delta at 800-443-9967 or 604-525-1655
7296 Wilson Ave
I haven't bought from them in a while, still using up the scraps, but they used to sell me sheets, custom cut to your width. Ask if they have off cuts.
Let me know how it goes.
7296 Wilson Ave
Hey Mike
Western Canoeing sells pieces of foam in various thicknesses.
But it's more economical to buy it by the full sheet, from the factory. They will slice it into any thickness(es) you wish.
Name of the company is Norseman Allfoam, in Langley, just off Hwy.1 at 200 St. As per Einar's note, they used to be in Delta, but they moved recently.
I found them to be respectful and helpful -- even if you're just buying 1 sheet.
I believe the webpage is www.norseman.ca
Get back to me if this link doesn't work.
Cheers
Rick
Cheers
Rick
C'est l'aviron. . . !
Re: Ouch
[quote="Einar"]
Embarr-assing
Nay, nay, Einar -- "bottom" line is I've learned much more from you than you ever will from me.
Besides -- what are friends for. . . ?
Embarr-assing
