Moderators: kenneth , sbroam , TheKrikkitWars , Mike W. , Sir Adam , KNeal , PAC , adamin
kimmieOC1
Posts: 137 Joined: Fri Nov 28, 2008 7:44 pm
Post
by kimmieOC1 » Wed Nov 24, 2010 3:53 pm
Can anyone tell me what's the lowest level on the Townsend gauge that the Sinks to Elbow section can be run and still have Class IIIish fun?
ckingoc1
Posts: 180 Joined: Thu Nov 06, 2008 4:07 pm
Post
by ckingoc1 » Wed Nov 24, 2010 4:06 pm
I think the lowest that I ran the sinks was 2.2ish. We ran down just past the Elbow. Thats also the the only time I've ran the Elbow.
But I've been told you can run it lower if you putin below the sinks.
kimmieOC1
Post
by kimmieOC1 » Wed Nov 24, 2010 4:18 pm
HaHa smurf
Chris, I'm thinking I've been on it down to 1.9 and it was still fun, but I'm not really sure that was the level, so I'm trying to confirm.
cheajack
Posts: 941 Joined: Mon Mar 31, 2003 2:43 am
Post
by cheajack » Wed Nov 24, 2010 5:03 pm
As you know the gauge at Townsend is well downstream. You should also check rainfall gauges in upstream areas; New Found Gap and Mt. LeConte for example..
oopsiflipped
Posts: 954 Joined: Sat Jun 03, 2006 3:32 am
Post
by oopsiflipped » Wed Nov 24, 2010 10:44 pm
depends on if it is going up or down b/c gauge has quite some time delay. 2.4 is pretty hard on your boat. 2.6 is starting to pad out.
pyc1
Posts: 49 Joined: Fri Aug 27, 2010 12:04 am
Post
by pyc1 » Sun Nov 28, 2010 12:42 am
2.6 is a reasonable minimum. Lower only if you enjoy hitting rocks.
