ok, I'm back home from a weekends paddling on easy class I and some class II sections.
I had great fun, learned some things
- I finally narrowed down my back-ferry
- I even did some back-surfing
- I did run a very neat line on a class II section
- my eddy turns are still sloppy.
- I did an side-surf with offside brace and later an in-water swim
- I have some work to do on my tilts. It has to be more pronounced and sharp. Too often some subtle body lean is involved.
Now, I tried carving into an eddy on my offside, using cross forward strokes. No good, I was pulling my bow against the main current, and it was hard work.
I do like cross strokes for short, narrow S-turns though, especially because I can controll speed and boat angle using cross-forward strokes.
I finally got a serious grip on a static draw when surfing
![:)](./images/smilies/icon_smile.gif)
Now I've been pushing my limits this weekend, doing hard moves on easy water which ended in 5 swims or so.
The sloppy eddie turns is mainly an issue on small, narrow eddies, especially those midstream things. It's probably a combination of speed-angle and which stroke to use when. Most of the time I do get them, but it costs way too much effort. Thsi problem actually brought me to the initial question, since it probably has to do with my eddie-problem.
oh, and indeed, downstream is not always the way to go. Sometimes one agressive pry is more effective then 2 or 3 bow strokes.
The teaching bit: I know. I'm assisting a local instructor (did so past weekend). I know it helps you to think about technique and watch paddling styles... . I'm working towards an Open Canoe Guide certification and afterwards to an instruction certification.
And probably, when it really matters, I think I use stern corrections. But then again, I'm still paddling way to nervous on class III water. Horrible timing, just getting down, not catching too much eddies, ... .
Work enough to do here. But I'm happy I found some new challenges on relatively "easy" water.
Oh, I do believe you (drewcanoe) on the 2x4 technique. Stern strokes are hard to learn and to master. I've been having a discussion with some instructors who start with a J-stroke. Those people are lost on the river after 1 day of flatwater. So making circles is more logic to understand. But you do have to master the tilt to do that.
The carving circles I have to work some more on that, try it some more. But it felt really bad carving an offside circle to catch an offside eddy.
Thanks for the feedback from all of you btw!
Oh, and my issue of Rapid did not make it to Belgium yet.
