OC2 Questions
drrpm
Post by drrpm »
I have a Mohawk Probe 14 with a triple saddle that I have used to take my daughters down section 3 of the Chattooga, starting around age 7. It worked well but I would skip the triple and go with 2 single saddles if I had it to do over. A Caption would also be a good choice. The Blast by Esquif would probably be good if you can find one.
Lengthy
Post by Lengthy »
Have you ever given any thought to a shredder? They are probably the most versitile boat on the water. You can be on anything from flatwater to class 5 and have a great time. Swimming in flat sections is easily accomplished by youngsters out of a shredder also, making for big fun on hot days. This is a boat you'll keep using long after the kids are into their own boats.
jrsh92
Post by jrsh92 »
Speaking of catarafts...
You can run ANYTHING in the "Argut" cataraft... I went on an insane river trip a few years back with two of those with a half ton of gear on each. If you can keep yourself tied down securely enough you can pretty much bomb down anything.
chriscanoe
Post by chriscanoe »
oc1paddlr i think we probably know each other as there are not too many people in Gainesville who paddle open boats. I was actually thinking I would take her on the lower Chestatee (60-400) for the first river trip.
Have you gotten out in any of this rain? I went and did the east fork of the little river this past week(little river as in Lake Lanier), which was a very interesting run. I do get up to the hooch some, just dont get out as much as I used too.
PBR ME ASAP!!
chriscanoe
I am leaning toward the probe 14 with the tandem saddle. Thanks for all the input.
PBR ME ASAP!!
golder
Post by golder »
i have a triple saddled probe 14. i've used it tandem w/ the mrs. and we've had a great time (no younguns though). i've used it solo as well. i picked it up pretty cheap this spring and have been glad to have it in the fleet. its very forgiving, making a good boat to get the wife into paddling open boat and makes a good boat for getting folks new to paddling on the water.
thats my dos pesos....
chriscanoe
Back in the day I paddled a probe 11, and basically ran all the big creeks and big water that I have ever and will ever do in thaqt boat. I wore two of them out. They are a darn good design, and I do not know why I switched to something else. Any body have any insight to how a Rodeo compares to a probe(just for solo andjust for my info)/
PBR ME ASAP!!
Carol
Post by Carol »
Speaking from personal experience, If you could find one, a Dagger Dimension would be perfect. We started my nine year old son paddling bow in our Dimension, dare I say 19 years ago. My husband quickly became an expert at paddling a Dimension solo, even class 3 rapids. When Chris was 12, he moved into a Mad River Flashback, and I started paddling tandem bow again. My husband says I need to clarify that statement: when we, the two of us in the Dimension and he in the Flashback, I would stop paddling until he was safely through. Mom genes!
But from our perspective, the Dimension was a perfect white water boat to start a child off in. It's stable and dry compared to the Caption F.. We also had a Dagger Caption, which is squirrely as all get out and I wouldn't start a beginner off in that boat. The[img]Speaking from personal experience, If you could find one, a Dagger Dimension would be perfect. We started my nine year old son paddling bow in our Dimension, dare I say 19 years ago. My husband quickly became an expert at paddling a Dimension solo, even class 3 rapids. When Chris was 12, he moved into a Mad River Flashback, and I started paddling tandem bow again. My husband says I need to clarify that statement: when we, the two of us in the Dimension and he in the Flashback, I would stop paddling until he was safely through. Mom genes!
But from our perspective, the Dimension was a perfect white water boat to start a child off in. It's stable and dry compared to the Caption F.. We also had a Dagger Caption, which is squirrely as all get out and I wouldn't start a beginner off in that boat.[/img]<OBJECT><PARAM></PARAM><PARAM></PARAM><EMBED></EMBED></OBJECT>
Carol
Post by Carol »
here's the picture I tried in above post...I'll get it right someday on first try!
Carol
[img]http://images.myphotoalbum.com/r/ra/rap ... .sized.jpg[/img]
ohioboater
More Dimension experience
Post by ohioboater »
I use a Dimension for my kids as well. Three saddles, with the solo position about a foot aft of where it "should" be, and the front/back saddles trimmed for adults. This trims the boat out reasonably for having a 40-90 lb kid in front and me in the center. I also have run it with me in the stern and both kids in front of me.
Pros of the Dimension - incredibly forgiving/stable, very dry, enough capacity to carry the kids plus the whole family's gear for overnights.
Cons of the Dimension - size/maneuverability. Mine must weigh 85 lbs (from the days of "good" Royalex). It's very maneuverable for its size, but a Blast it ain't. I can horse it around ok in easy class 2, but that's about the upper limit if your kids can't help move the boat when needed.
