what can you tell me about a prelude?
Either one
Hey Big Spenser,
I am 6'3 200lbs and both a Solito and Prelude feel fine for my size and weight. For durability and creeky paddling Prelude will last much longer.
jim
jim
- bigspencer07
- kabuki_blaze
Just my two cents, since I have paddled the detonator and the prelude. I am a big guy, 6'3 220 pounds. At my weight and height (I am a class 3+-4 paddler) I found the prelude to be very unstable and VERY TIPPY. I paddle the Detonator now and love it, i found I got the responsiveness of the prelude and gained the stability I was looking for...People swear by the prelude and I love the plastic, maybe it just takes a better paddler as you get taller and heavier. I wanted to love the prelude, but it just didn't happen.
I'm about 220 and have spent a grand total of 20 minutes in a Prelude - I wanted to like it and maybe could have w/time (and diet!) Stability wasn't the deal breaker, it was speed. 220 is just too much in that boat.
I've spent a couple of hours in a Spark - awesome boat, but quite different. Fast. Stable enough. "Nimble". I wouldn't turn one down but would probably consider composite first.
Its faster than a fly. And drier than a Skeeter although I find the Prelude a little less stable than a Skeeter.I'm about 205sbroam wrote:I'm about 220 and have spent a grand total of 20 minutes in a Prelude - I wanted to like it and maybe could have w/time (and diet!) Stability wasn't the deal breaker, it was speed. 220 is just too much in that boat.
prelude
i tried to just sit in the bugger and could barely do that.the outfitting sucked,and i was still a rookie.I'm 6'0 and 190lbs.I'd like to try one with good outfitting but i look at it and i'm sure the results would be the same.No real edges,kinda' round with wicked rocker!Love to love it,but...
- bigspencer07
Re prelude,
I think I'm rather a small lad compare to youse lads...I don't do imperial so I'm 1m82 for 74kg.
Also changed the outfitting that seemed to have been the original prelude one. Got my knees more spread out and cut about an inch or so ? (2/3 cm).
I didn't know any better before since that's the only boat I've ever paddled...but hades it's now super stable
Erick Baillot
- agrestal
I paddled ncdavid's pyranha prelude a couple times at the WWC and it was fun but super heavy and slow. You do have to keep an active blade in the water - it's a little more stable with some water in it, but that's even more weight. I thought it felt significantly more stable in rapids than on the flat water. (It was funny to have 3 kayakers get in it at the top pool and immediately flip on or before the 1st paddle stroke!)
I got in mac's maxim and loved it for all the same benefits the prelude has, but it doesn't seem nearly as heavy and maybe that's part of why it doesn't seem as slow to me. The initial stability seems greater without giving up any secondary. If you're near NC and want to try my maxim (had to have one!) you're welcome to.
canoera hasta la muerte
www.CostaRicaRios.com
- Todhunter
- Ridge Spirit Outfitting
Shannon - you think the Prelude has even LESS initial stability than the Maxim?
I do love my Maxim! It is very light, even with a bulkhead and pump. Mine is Royalex (not Royalite) and is very solid. With S-glass skid plates, it takes abuse very well, and I'm a novice paddler, so I do hit rocks frequently.
