Sources for valves for Voyageur/Harmony float bags?
chuck naill
Re: Sources for valves for Voyageur/Harmony float bags?
Post by chuck naill »
If memory survives me, I used Vinyl Bond, Bernie.
pblanc
Post by pblanc »
I have used vinyl adhesive to attach these valves as well and never had one come off.
Since the vinyl adhesive results in an immediate tack bond, it is a little tricky to get the valve fully inside the larger diameter filler tubes but it can be done. Getting the smaller filler tube into the open end of the valve is pretty straightforward.
