There's just one stroke - put your paddle in the water, move as needed, extract, repeat...Craig Smerda wrote:...
What does it mean when you really don't think about what you are doing out on the water or what the names of the actions you are doing are called but it all seems to somehow work? Cuz... I think I'm that guy...
Anyone use all of these pry's on a regular basis?
You're still a youngster!Craig Smerda wrote: What does it mean when you really don't think about what you are doing out on the water or what the names of the actions you are doing are called but it all seems to somehow work? Cuz... I think I'm that guy...
Trying to teach someone else to do what I do is a greater challenge...
Perhaps why some of the best paddlers, are not the best of teachers... and the best teachers, not known as the best of paddlers... compounded by the fact, that we have to get past thinking about what we are doing, in order for what we are doing to work.
- Jim Michaud
I'm pretty sure that the only stroke that I DON'T use is the righting pry. I did learn the righting pry when I was a newby but gave it up as a lost cause. All too often the tip of my blade would hit a rock during a righting pry. The canoe would then hit the paddle shaft and tear it out of my hands or flip the canoe. I've long ago switched to draws and cross draws. The only pry that I still use is the stern pry, when needed.
Re: Speaking of underwater recoveries
Yup, I use the skull a lot. In the current, and in the eddys. I use it to lign myself up for surfing or to get on line with my target. or to get out of the way of huge rafts. I believe that shorter boats react way more to draws, prys, and skulls, than longer boats. I'm sure a lot of others would agree.RapidMediaTVGuy wrote:iRolled do you ever use a sculling pry? I find on flatwater I use it a little bit but never even think about it in whitewater. It seems I immediately crossover and draw instead. Just feels more natural (or maybe easier) to me. I wonder what is more effective though? I'm all about always having a blade in the water as without it the river is in control so maybe I should be working that pry a bit more.
Dan Caldwell
Rapid Media TV Guy
Team Blackfly
