even more seatbelt stuff
Aric
Post by Aric »
I posted on an earlier discussion about my setup being a one pull system, you pop your skirt and your belt releases also. I did this by drilling a hole in the quick release buckle and tying a line to it. the other end of the line has a loop the skirt pull tab goes through.
I think James asked if I could send a picture.
Aric
[img]http://www.geocities.com/aricandbec/outfit1.jpg[/img]
http://www.geocities.com/aricandbec/outfit1.jpg (geocities doesn't seem to like deep linking)-MOD.
PAC
thanks...
Post by PAC »
The picture is not displaying on my PC can you also add the URL for the photo? Thanks!
Guest
sorry
Post by Guest »
sorry, I'm new to adding images, and such, try http://www.geocities.com/aricandbec/cimage.html If that doesnt work could someone email me and help me figure out how to add images?
Aric
Guest
Post by Guest »
geocities is weird, try cuting the URL and then pasting it into your browser window and adding a space at the end.
The lap belt is very nice, how well does it work during a wet exit?
Aric
wet exit
Post by Aric »
it works well for wet exits, the loop on the red line goes out to the skirt pull tab, so when you pop your skirt the belt releases also.
Aric
C1Deli
Backpad?
Post by C1Deli »
It looks like you back pad is threaded through the cockpit rim -- so how do you stop leaks there?
I am just about to outfit a boat using a back pad, so any hints welcome!
/edwin
______
More nonsense like this at
http://www.biothinking.com/paddle/
Aric
Post by Aric »
that backband was on the boat when I bought it, it leaked then and still leaks now. I squirted some aquaseal into the holes after I had adjusted the band, but it doesn't keep all the water out. next I'm going to try silicone from th hardware store, I hope it works better...
Aric
