seat placement T2
Guest
seat placement T2
Post by Guest »
how far from the rear of the cockpit rim should I glue my seat in a wavesport T2.
Ryan
Brettal
Post by Brettal »
If you have a friend and access to a pool (or other body of still water), you can use what's in the C-FAQ to figure out where it goes:
http://www.cboats.net/faq/conversion.shtml#in
and
http://www.cboats.net/faq/outfit2.shtml#position
That way, it'll be customized for *you*, in case your leg:body proportions are different than other people's. What other people might tell you of measurements will probably be close enough, if you don't have a (willing, helpful, convenient) friend or a pool.
Kevin
Post by Kevin »
Trim it out in the pool!!!! Get someone to look at you while your in the water. A must do.
Drop Waterfalls, Not Bombs
