Segmentation fault: where is the bug?
giuliano
Post by giuliano »
Hi all: these lines of program cause a segfault on my Linux machine:
/* testptr.c */
/* gcc -o testptr -Wall -g testptr.c */
int main() {
char *name = "Giuliano";
*name = 'X'; //here I get a seg. fault
return 0;
I've tried to found the bug using GDB:
gdb testptr
Starting program: testptr
Breakpoint 1, main () at testptr.c:2
2 char *name = "Giuliano";
(gdb) step
3 *name = 'X';
(gdb) step
4 return 0;
(gdb) print name
$1 = 0x80483e8 "Xiuliano"
(gdb) step
5 }
(gdb) step
0x400397f7 in __libc_start_main () from /lib/i686/libc.so.6
(gdb) step
Single stepping until exit from function __libc_start_main,
which has no line number information.
Program exited normally. (No seg. fault !!!!!!!!!!!!!!)
So, where is the problem?
Thank you
Giuliano
Judd
Post by Judd »
umm. maybe you didn't look real close to this site before you posted..... notice a lot of information about paddling and boats, and very little information on writing c programs. :)
Jan_dettmer
Post by Jan_dettmer »
$> cat your_message > /dev/null
Kai
Post by Kai »
Try this:
- first some open boating on some nice river. enjoy nature. free your mind.
then you might consider using the data heap:
/* testptr.c */
int main() {
char name [] = "Giuliano";
name[0] = 'X'; //here I get a seg. fault
return 0;
Martyn
Post by Martyn »
now that's scary - overloading the forum name :wink:
