thigh-strap anchors
Mike W.
thigh-strap anchors
Post by Mike W. »
What is the best thing to use as thigh-strap anchors in a glass boat? My Viper had d-rings on plastic pads. One blew :evil: on the Gauley last weekend & I'm thinking of replacing both. I don't really like what was in there so I'm looking for suggestions. I'm using 2" wide straps. I want something that has little resistance to the strap feeding through so adjustments will be easy. It's got to be strong too.
mshelton
Post by mshelton »
Hey Mike,
I used rectangleular shaped 2" stainless "rings" in my Viper, made the base out of glass by putting a couple twigs under some wax paper to make a mold glassed it over then cut it to fit the rings, inserted the rings and glassed it to the bottom of the boat. Seems to work real well and I don't think it'll ever come off. Let me know if you want me to send you a picture of it.
Mike W.
Post by Mike W. »
Hey Marshall, I wish that I had paid attention to your anchors. The seat was so comfortable :D that I didn't think much about the rest of it. I'd like to see pictures if you can send 'em.
watson@telpage.net
pevans
Post by pevans »
You could also take a few inches of one inch webbing and glass the ends down so that you can use the middle as an attachment point.
- Paul
the great gonzo
Kevlar rope
Post by the great gonzo »
One really sweet setup I've seen once was a piece of kevlar core rope where the ends were opened up and the kevlar fibers spread out and epoxied directly to the hull. Looks really nice and strong.
The center part is still a piece of rope, which makes it really easy to fit the straps through.
martin
Guest
Post by Guest »
Own a glass C-boat boat?
You need the following books:
Walbridge's Boatbuilder's Manual, and
Walbridge's Canoe & C-1 Outfitting
Both are available through Amazon.com at less than $5 each.
