So, what's new, other than that Davey and Jon didn't design them as stated on this site (taken from the New Wave catalog...).
Well...get ready for this...the boats were designed in a similar fashion to the Maven-Peter took the hot slalom boat of the day (a Max II) and cut it in half in both directions to narrow it, then messed around with plastic body filler to reshape. The result...The Edge! (around 1981-1982)
The resulting boat looked a lot volume-wise like the next hot slalom boat...the Batmax....so he started with one of those and tweaked it in the same fastion...
the result...The Aerobat! (1982-1983 ish..he recalls working on it right after Davey and Jon had finished the Batmax, as he had seen Jon on the river, gone over to check out their new boat, and obtained permission to pull a boat and modify it. My records show the Batmax as a '82 design.).
He wasn't completely happy with the results, so kept slowly working on it, and finally figured out how to cut down a boat from the Aerobat mold to make a pretty sweet squirt boat...the Acrobat (circa 1987 or 88).
He then decided to work on a new boat, more for creeking and cruising, and hence was born what he feels is the best of his work-the Descender.
Understanding how the boats were designed, I can now "see" it, and find it fascinating how his designs were ahead of their time.
The one confusing point seems to be that some of the "Edges" have wings, and look different than he recalls (the Max II was pre-wing). I'm left wondering if perhaps the "Edge" a few of us own is NOT just a cut down Extrabat as I've surmised. Peter is going to try and find someone to scan in several of his old photo's....we should be able to tell from those.
I'm also trying to convince him to join us for the June Armada...he doesn't CBoat anymore due to a knee injury, but I think it would be great to have him along!
(and, yes, in case some of you are wondering, I DID just finish doing the outside seams on the Maven...
