elbo pain
- ghetto johnny
elbo pain
i've recently started to get some pain in my elbo's.
i paddle lefty, and am getting it on my left elbo, it's on the inside arm and getting tender
just wondering if others have expeirence the same pain
thanks
john c.
cincy,ohio
thanks
john c.
cincy,ohio
Half the paddle, Twice the man
tendonitis?
could be tendonitis. I've had it for a while as well. I don't have it anymore since I switched to paddles with more flex; wood shafts are good. Also H20 paddles if you get them with the glass shaft.
...And....
,,,And it sounds pretty far fetched, but I heard ~10yrs ago bout' the relationship between the innertube around one's gut, and one's elbow health.... Can't remember what it was based on...but aside from the normal issues...keeping one's upper body toned....not enough help from the back/torso, etc...I can't toss it off as rubbish...fwiw..
$.01.....![:-?](./images/smilies/icon_confused.gif)
$.01.....
think about your grip in addition to other comments
I had the same thing happen while racing. A review of form found that I had gripped the shaft way too tight. As an MD who has specialized in sports injuries I have found that ice, emu oil, rest elbow (2-6 weeks, no paddling), and when the pain is gone, wrist exercises and grip strengthening. Relaxing the grip and getting a larger shaft on the paddle helped too.
My 2 cents.
My 2 cents.
Shaft diameter
Good recommendations! Another consideration may be a smaller paddle shaft. A larger paddle shaft actually allows you to generate more force when you grip it, so smaller may be better.
The real trick is to have a relaxed grip on the shaft. A death grip on the paddle puts a lot of strain on the muscles that close the hand. Focus on relaxing your grip when on easy water and with practice that will carry over to paddling on tougher water.
Jim
- ghetto johnny
glide difference would increase stroke rate
If you mean regarding your elbow- a shorter C1 would result in more strokes increasing the risk of persistent tendonitis. As 2 of us have said- keeping the shaft hand grip loose (in your case left hand) is the key to avoiding tendonitis.
Re: glide difference would increase stroke rate
Make me 3 - when I have tendonitis type symptoms it is when I'm "overgripping" - some times on a tense run, some times on a long day with a lot of play.Wendy wrote:If you mean regarding your elbow- a shorter C1 would result in more strokes increasing the risk of persistent tendonitis. As 2 of us have said- keeping the left grip loose is the key to avoiding tendonitis.
In my experience, it was worst for me with my paddle that has the largest diameter shaft (and I've got pretty big hands) - I find a "normal" to small shaft works better. So, maybe too large can be a problem, too.
She had verified "Ghetto Johnny's" shaft hand, which is his left.Wendy, don't you mean "shaft hand" rather than left?
While many of us do retain a floatable innertube around our tummys (me includedthe innertube around one's gut
Ditto on the relaxed grip, smaller paddle shaft size, paddle shaft flex, and care for the injury (Emu oil?
![:o](./images/smilies/icon_eek.gif)
KNeal
Emu oil for tendonitis, joint pain
I have found emu oil is excellent for reducing joint pain, tendonitis, and skin problems. It doesn't have the side-effects of NSAIDs. If you decide to try it buy the oil, not the cream. a little goes a long way- used 2-3 times a day. Here is one link to read for those interested:
http://www.emu-oil.com/properties.htm
