Through the Pain Barrier once more...
All c-1 boaters must face the issue of how low to set the seat, and everything else that goes with pain control.
After gronking my knee a few years ago, I had to give up my Zealot, and even the 7.5 inch seat in my Wide Ride was causing too much pain and poor circulation. But the knee has recovered, and today I was messing with both boats in the basement, doing whatever I could to make paddling bearable.
One thing I learned is that pain is not a simple function of seat height. There are some other details about how the knees are spread, and how the feet lie on the bottom of the boat, that have more to do with comfort than I expected.
I have always used foam knee blocks to spread my knees. If I don't do this, if I rely only on knee cups and thigh straps, then I get a strange kind of knee pain evidently caused by sheer forces inside the joint. With knee blocks, this pain is absent.
I've tended to use fairly wide knee blocks to spread the knees for control and to get my thighs out against the inside of the cockpit rim for more positive rolling and control.
But now I realize that I've been trying for too much knee spread. No c-1 has a perfectly flat bottom, and the more roundness there is, the more the bottom of the knees are raised relative to the lowest point of the boat, and relative to your feet. The farther out to the side your knees, the more your knees will be flexed. Think about it and you'll see why.
So in my Zealot, after raising the seat height to 7", I still had a lot of pain on entering the boat. So, seeing the probable effect of my knees being spread to wide, I carved the knee blocks back about an inch. The result was a marked improvement in knee comfort.
Next, it occurred to me that if the knees are spread, then the feet want to be closer to the center of the boat. So I pulled the Zealot seat out and carved deep pockets in the trailing foam slabs (which locate the seat along the rear wall) so that my feet could lie where they wanted. This also resulted in less pain cramming into the boat. (Note that, at 6' 5", I do not have a prayer of getting my feet up on my toes or using toe blocks. The tops of my feet lie flat on the bottom of the boat.)
Next I went over to my Millbrook Wide Ride and tried it on. The knee spread was not excessive. The trailing part of the seat pedestal did not need carving. I decided the seat could stay at 7.5". I would like the seat higher, but the Wide Ride does not have nearly as much initial stability as the Zealot, and might feel spooky with a higher seat.
I want to add that improperly placed thigh straps can also cause knee pain. The worse the placement, the harder people crank the straps down to compensate, and the more discomfort. For the best comfort and control, the strap attachments should (IMHO) be about 6" forward of where your butt bones sit, epoxied to the seam; this may put the upper strap attachments a bit back of the cross-center of the cockpit. The center attachments, on the bottom of the boat, should be maybe 5" to 6" back of where your knees sit in the cups. This is where Adam Clawson had the attachments when he sold me the Zealot, and it is just right. The straps pass diagonally over the tops of my thighs, which distributes downforce for comfort and maximizes support when one is upside down.
Those confronting the outfitting of a c-1 for the first time tend to have the lower, central strap attachment points too far back, so that the straps pass almost at right angles to the thighs. This makes it harder to thread one's knees into the boat, and more (painful) downforce is required than with the diagonal orientation. My Wide Ride, bought used, had the crossways strap orientation, but I was able to correct it without putting in new attachments by putting heavy Tygon tubing around the attachment webbing to force the lower strap attachment to the forward extreme of its range.
Pain boaters face two kinds of pain. One is initial pain associated with struggling into the boat. It may subside, but with proper outfitting, it can be made to go away.
The other kind of pain is the kind that grows after a half hour of compromised circulation. It isn't as dependent on outfitting. Get out of the boat and shake it off.
I don't know whether I will be able to paddle c-1 seriously again. At 64, I have to treat the issue of ischemia and thrombosis in the legs more seriously. But all these issues also apply, to a lesser extent, in my open boats. Maybe all these fussy details will help someone; hope so. :roll:
knu2xs
Post by knu2xs »
try some sort of system to get your feet under your butt. I've used a tractor seat in the past. This more closely aligns the joint facilitating circulation. The best boat I've ever been in, I actually had the balls of my feet overlapping. I could stay in that boat for a long time with no worries.
-Joel
You can't wait for inspiration. You have to go after it with a club. -Jack London
ChrisKelly
Joel 's feet did not hurt. ha ha ha
Post by ChrisKelly »
Joel is , like 9 years old. Well, he is actually in his 20's but you get the point.
Serously, I really appreciate this discussion because it contributes to the bodyy of knowledge about outfitting.
it also makes clear that I am not the only old geezer who whines about his poor legs and feet.
Chris Kelly
mshelton
Post by mshelton »
Pretty good reading ez.
When I go home tonight I'm going to take a closer look at some of my outfitting as it relates to some of the points you made. I'm 6'5" also but my saddles are all 6", this is for stability and also it helps me get my legs under the cockpit rim. I recently outfitted a Burn with the 6" saddle but it seems to be the most uncomfortable boat I have, this may have to do with the bulkhead installed in it and how it holds my knees apart along with feet placement.
I do agree with what you said about the placement of thigh straps, I've seen a lot of setups where the straps are perpendicular to the thigh minimizing the contact area. I prefer my straps to start just in front of my hip bones then end up about half way down the thigh. Seems like this gives the greatest coverage spreading the stress over a greater portion of the leg and holds me in the boat much more securely than straps straight across mid thigh, almost as good as a lap belt for keeping the butt on the seat.
edg
knee comfort
Post by edg »
I'm with Joel on this. Getting the feet touching or overlapping seems to greatly reduce knee pain, at least for me. I'm short (5'8") but have large feet (10.5 -11). I've started cutting or carving the bases of my saddles in an almost triangular or olive shape, with the narrow point towards the back of the boat. This cut out only extends an inch or two up from the bottom of the saddle, and doesn't affect the width or shape of the top. Doing so doesn't affect the adhesion of the saddle, but does allow my knees to splay comfortably to the side with my feet touching and under my butt. Even in my early 40's, I do worry about the thrombosis issue. It's one of the main reasons I've never raced the full 26 mile Fibark. Good Luck......edg
PAC
Post by PAC »
Good reading... sounds like folks are finding body placement zen in relation to boat(s). All I'll add is ankle blocks... placement is key and it helps if they are made out of a softer minicell like material - I like to use old pfd guts. Soft, float and re-cycled - usually easy to find - just your kayaking pals for there old unwanted jackets. :-)
My $.01 Paul C.
John Coraor
Post by John Coraor »
The desire to allow my feet to come together under my seat is actually one of the reasons that I've stuck with old school seats in some of my older C-boats. I still have bent aluminum thwart seats in my C-2s (they're suspended from the deck rather than running all the way across from seam to seam) and a composite "tractor seat" suspended from the deck in my old Batmax C-1 with the stern pillar extending under the center of the seat and a cut-out in the pillar for my toes. I find both of those arrangements more comfortable than the pedestal seat in my Zealot, although somewhat harder to get in and out of.
Of course, the other reason that I haven't changed those old seats is that I'm lazy. :wink:
John
The walls in both boats are pretty narrow, and so my feet are fairly close together, but it might be possible to actually put a little arch in the wall where the balls of my feet want to come together.
I do agree that it is helpful to get the feet so that they are at least better in line with the thighs. This gives two related parameters to play with, the amount of knee spread and the ability for the feet to "follow" knee spread by being in line and close together. The less the spread of the knees, the less the need for the feet to be close, but for some that closeness may still be desirable.
Just don't forget that, to the extent the bottom of the boat is curved and not flat, the farther the knees are spread, the more the knees are bent, and the more the feet need to be under the paddler.
I feel a bit ashamed of going to a 7" seat height after so many years at about 5.75, but after all I am pretty big. And some time on that minicell saddle will cut about 1/2" of effective seat height as the foam compresses.
Another point I didn't mention..... Most of us adults have a preferred knee that we go down on when we kneel. In my case it is my left knee. This knee is so much more flexible, that, once, an orthopedic surgeon was SURE that I had an anterior cruciate ligament injury. But he was wrong. A lifetime of going down on that knee when kneeling has kept that ACI flexible, while the right one is normally tight. Fortunately for me, I paddle mostly off the left, and my more flexible, more comfortable left knee is able to take that little bit of extra flexion as the boat is heeled to that side. The tightness of my right knee makes long stints of paddling off the right a bit uncomfortable.
Just as a sidelight, look at the way young children kneel, or actually sit on or between their calves. They are so flexible that their lower legs can splay outward with their feet far apart. The Olympic c-1 development program should start with these kids while their legs are still flexible!
oc1paddlr
pain
Post by oc1paddlr »
alittle BC powder in my dry box also helps me along
paddlr
red boat ready
philcanoe
Post by philcanoe »
good info...and it works for open boats too
first noticed that my heels had worn notches in my old reliable saddle about six inches up (a guess), as I use toe blocks and my heels are way up there. On new saddles the wear was not as severe and the comfort was not quite there.
...also in the past have found that swapping the factory supplied bulkhead, from side to side has helped. This puts the knees closer to the saddle. A inch of extra foam on the saddle and I'm good to go. With no meniscus and later ACL repair before the days of arthroscopic surgery every little bit helps.
And best of all the boat is a 'Wee Bit' more responsive.
One question, what effect does this have on rolling... is the roll quicker/slower, stronger/weaker, not much/noticeable ????
