Lap Belt or Thigh Brace for C1
Lap Belt or Thigh Straps for C1?
Lap Belt.
1
5%
Thigh Straps
2
10%
Bulkhead/Lap Belt
6
30%
Bulkhead/Thigh Braces
10
50%
Just Bulkhead, Im a rolling/outfitting/just plain god, I don't need either.
1
5%
Total votes: 20
msims
Post by msims »
Hey there pollers.
Lots of talk about lap belts these days. I'm more interested in C1.
What do peeps do here? What's popular? Why/Why not?
I'm planning to put the lap belt in with a quick release VW beetle steel buckle. Mainly because 1) I've never gotten thigh straps to work well 2) I have a spare one.
Thanks, Mike.
________
H ENGINE
Mike W.
Post by Mike W. »
I like the bulkhead/lap-belt combo.
If you swim much you probably don't want a lap-belt. They are great at holding you in the boat, but they do that wether you want them to or not :-?
One geeky tip: Decide which hand will hold your paddle when you swim. Then set the cam-buckle where it will be easy to pull w/ the opposite hand. ie: I hold the paddle w/ my shaft hand (right) when I swim. I pull the skirt, reach under & pull the buckle w/ my left hand. So I have the buckle right of center & I pull from right to left to release it.
cheajack
Post by cheajack »
I like double thigh straps the best. Thickness of clothing winter to summer does not make a difference as it might with a bulkhead. I currently use 2" webbing and fastex buckles on the lower one and Brown Pack straps on the thighs. That said, I'm currently doing a "Y" convrsion and first run will be a bulkhead and Brown Pack straps because I liked the looks of Bernie's set up.
bearboater
Post by bearboater »
I don't use either. Bare Bones, no outfitting, I'm a rolling god.
but the bilkhead/straps work as well, foot pads are increasingly important... to stop you from sliding back out of the outfitting.
skaal
-isaac
fez
Post by fez »
in any case I think it`s great to open up the skirt and the thigh braces or lapbelt or whatever in one.
(picture of Raphaels Habitat without the seat)
imagine
cheajack
Post by cheajack »
Foot Pads? Is that the same as toe blocks? How are you making them so that you don't feel/get trapped?
I can't decide, so I have some of each. A Score with bulkhead (adjustable) + thigh straps, a Rockit with double straps, a Slasher with just a bulkhead, a Maverick with just a single strap, a Zephyr with just a bulkhead, an ME with double straps, but nothing with a lap belt... I tried it once, might try it again.
kneeler
Post by kneeler »
sbroam wrote:...Slasher with just a bulkhead...
Got any pics of the Slasher with just a bulkhead? I've got a Slasher with some outfitting issues and could use a little inspiration.
It's the original Slasher factory bulkhead - I think the last ones had the same outfitting the Gyramax had. I never could get comfortable on the factory pedestal, I fabbed up one of my own. I'll get some pictures up in a bit. They'll be here :
bearboater
Cheajack,
I do toe blocks/foot pads so the contour of the top of my foot is mirrored in the foam, and a toe block so my foot wont slide back any farther than it is when I am fully into the outfitting, so I slide over it to get in, and then sink in when I am down on my stupidly low saddle.
getting out will probably be slow, but so it goes. I hope to not be swimming from the slalom boat too much, save for when paddles break...
skaal
-isaac
John Coraor
Post by John Coraor »
I indicated bulkhead/thigh braces as that is what I'm using now, but I used to get by with bulkhead only when my wife and I raced C-2M slalom. I used the end of the stern wall as my toe blocks for both feet as the C-2 is outfitted with a hanging seat that, unlike pedestals, allows you to put your legs underneath you.
John
bearboater
matt taylor also had a similar set up to what you are talking about john, in the olympic boat from 04, there were no straps, but a well shaved saddle with foot room below, and a bulkhead with shin support.
cheers
-isaac
cheajack
Post by cheajack »
Does anyone know a current source for old style Perception toe blocks for OC-1?
Craig Smerda
L'Edge Designer
Post by Craig Smerda »
In all honesty... I have absolutley no outfitting what'so'ever of any kind in any of my boats. I flip over and the boat just clings to me for dear life. :lol:
I realized a long time ago that just as important as outfitting was an actual commitment to staying in the boat. When I developed that, it was amazing how much better even sloppy outfitting would work! Without it, even great outfitting can fail... Personally, I end up with a slightly loose set up for comfort that I "cling to for dear life" (sort of) when I need to. That also means that when my commitment to staying in the boat wavers, well, then I can blame the outfitting :lol:
Note : Craig's post was funnier.
