removal of marks on hull
TonyB
Post by TonyB »
I just got a new to me Nitro and it comes with its own set of batttle scars.
Included are long black marks supposedly made from other boats during transport.
Soap and WD40 dont seam to work in removing the marks . Whats a good removal agent that wount destroy the roylex?
Proud Yankee
philcanoe
Post by philcanoe »
a low water (steep) creek might just do....
Louie
hades FIRE PHILL
Post by Louie »
that was a smart butt answer, wish I would have thought of it. I was just wonder why anyone would want to clean it up.
philcanoe
Post by philcanoe »
must be those restrictive neighborhood covenants... maybe putting it inside a Sprinter Van would work - and then all the women would have a place to change :wink: you'd be way popular
PAC
Post by PAC »
For most marks if elbow grease and WD don't remove them you might as well not risk the hull and leave them be.
Having the buzz of getting a new boat (at least to you) is a good thing, particularly if its your only one or close to that.
Although some of the boat pimps :wink: have whole stables of boats and can't even keep track of them or what condition they are in (or don't care - guilty here :cry: ).
That said - what do you plan on using the boat for? If its bigger water without rocks and you really want to clean it up to just like new just stay at it with elbow grease - just take care to not wear through the cover coat. If you are taking it creeking and on low flow runs you might want to re-think the effort - by the way canoest dig boat scars!
If the marks are from other boats in transit they will slowly work out if you water (paddle) the boat frequently. 8)
Good luck and have fun. Paul C.
TonyB
Post by TonyB »
Thanks, Im in process of moving so Its just sitting there all taunting
me while I pack and clean the real world junk.
the boat will be profusly paddled on low water "this is eastern pa"while I practice my skills and attempt to move from class II-II river running in my old ME to the next level.
It was bugging me that these battle scars where not mine and I couldnt put mine on yet.
Im like a little kid with a new bike watching the commercials while it blizzards outside.
I'll cover them with my own marks latter.
Proud Yankee
philcanoe
Post by philcanoe »
pressure washer?
Eric Nyre
Post by Eric Nyre »
Acetone will take any marks out of the hull.
Very lightly dampen a paper towel with a little Acetone. Lightly wipe on the area you want cleaned up. Don't soak the paper towel unless you want to do a nasty repair.
WARNING: Acetone will dissolve the outer skin of your boat. That's partially how this works, since it will dissolve whatever the mark is plus a little of the outer hull. It can make the boat look cleaner, but you're thinning the skin and risking some nasty damage.
Mike W.
Post by Mike W. »
Acetone is absorbed through the skin & attacks the liver. Wear gloves. A respirator is a good idea too.
I'd like to hear some evidence about the potency of acetone regarding liver damage. I've had the stuff on my hands for decades, and all my liver function parameters are absolutely normal.
philcanoe
Post by philcanoe »
the way I heard it...
acetone breaks down whatever it's removing into smaller more easily adsorbed matter, so the toxicity will very... needless to say a good liver is hard to come by
... cheers Image
It's surely much less dangerous than a host of solvents contained in the various glues we use.
If one is going to use quite a bit of acetone for a significant time, wearing gloves is surely worthwhile, and if one is working indoors, a chemical mask might be worthwhile also.
But as solvents and cleaners go, acetone doesn't have a reputation for being dangerous. Or, if it does, I want to know the data.
Just sniffing my evening toluene......
Mike W.
Post by Mike W. »
I found some interesting info. The National Institute for Occupational Safety & Health says to prevent skin & eye contact. They also have respirator recomendations.
http://www.cdc.gov/niosh/npg/npgd0004.html
What's bizarre is that OSHA says that acetone is listed by the FDA as permitted for direct addition to food for human consumption :o
even though it lists irritation of eyes, nose, throat & skin. I don't know about you, but I don't have any acetone in the kitchen.
http://www.osha.gov/dts/chemicalsamplin ... 16600.html
Personally, I have some acetone. I use gloves & a respirator. As soon as this can is gone I'm done with it. Mineral spirits will do the same job w/ the same efficiency w/o the (potential?) health hazards.
Here is a link that echoes what I found on other links.
http://www.ccohs.ca/oshanswers/chemical ... h_ace.html
Breathing it is not a hazard at levels we are likely to encounter in the basement or garage.
Occasional skin exposure (such as when using acetone nail polish remover) is not a hazard. Frequent use without gloves will tend to cause skin dryness and damage.
Its main risk is its flammability.
gumpy
Post by gumpy »
So I should keep it away from my Detonator? :o
