ocoee or viper
ocoee or viper
I am looking at getting a more aggressive boat. I have paddled a prodigy x, probe 13, and I have an encore. I have paddled an ocoee a few times and liked it. Was wanting some input on a viper 12. I am 5'10" 220lbs. I know I will have to get used to the edges but which boat is the better choice to advance in. Thanks
About your size exactly. I paddled a Viper 12 for years and loved it. Fast. Responsive. Dry. Spent a couple of hours in an Ocoee last year - awesome boat. Snappy turns. Great surfer. Can't go wrong with either, though, as hard as it is to say this, I think I give the edge (heh) to the Ocoee... But then again, it's been a while since I was in a Viper, I might need a refresher... I'd like to try a Viper *11* again just cuz...
Re: ocoee or viper
Either.
Try both
The Ocoee is probably the more progressive design of the two mentioned.
The Viper may be an easier transition from the boats mentioned.
If strapped for cash, have an option for a $400 one or $800 other (given they are in similar condition) I would take the cheaper.
If money is not much of an issue but you can only buy one, it may come down to whether you want slightly easier transition from what you are used to, or slightly more progressive than that.
If money doesn't matter... buy both
By the way... try both
Try both
JD
Viper 12 is a faster boat than the Ocoee, but 16" or 18" longer.( I can't remember; is the Ocoee 11' or 11'2"?)
I prefer the Vipers myself, having owned a 12 for years till I wrapped it around a tree. I fixed it, sold it, and bought a Viper 11 and a Prelude.
At your weight, I would think the Viper12 might be better for you than the Ocoee. However, the Ocoee is an awesome boat also. Though, I've never paddled the Bell Canoe version only the Dagger and they aren't making them any longer. or any shorter.
dance for rain
Note that there is an occasional poster here who I'm pretty sure is a tad north of 250 who paddles the Ocoee - a little wetter, but it still performs very well...
Actually there is a shorter Ocoee. It's called a Solito and it's made by Evergreen. Very similar edges and bottom, but only 9'10". There are some great shots of Olivier Chatigny paddling one on his site (http://olicanotboy.spaces.live.com/). I prefer my Solito over my Bell Ocoee.
The Bell Ocoee is a great boat though. It's a little narrower than the Dagger version and thus more edgy. One thing I don't like are the Bell gunnels. They're wimpy and if you're not careful you could even crack them cinching your boat too hard down on your car's racks. (I have a friend who did that.)
Weight limit on Solito
Before the designer of the Solito died I had corresponded with him. The upper weight limit for it is around 180 he told me. BTW- Frankie didn't design the boat, but very similar to a short Ocoee.
I have both a Dagger and a Bell Ocoee and I find the Bell construction (gunnels) and outfitting to be quite cheesy by comparison. The loops that guide the string for the bag cages are pulling out. The problem with that is they also rivet the gunnels to the hull. The gunnels flex quite a lot as well compared to my 1998 Dagger Ocoee. The thigh straps are inferior to those in either the Dagger version with Team Edge outfitting or the outfitting in my '06 Detonator. The Detonator is a much more solid boat with more thoughtful outfitting, the problem there is the concave bottom causing the excess wear on those double chines.
Hi Milkman,
If you prefer your Solito to the Ocoee, I'm guessing you weigh well south of 220 lbs? Most 220-pounders probably aren't looking for a smaller Ocoee!
Louie,
If there are better 'non-dated' hulls for the average 220-lbs paddler, let's have the specifics!
The Zephyr is the only other one I'd think of (I guess the Nitro or Detonator, but persoanlly I don't like them and they don't seem to have the following of the Ocoee or Vipers), can't think others unless it for a specialized, exceptional paddler I'm sure there are examples of bigger guys in Preludes or Tareaus, but probably not for everybody.
JM,
I'm in exactly your position, I haven't had much a chance to paddle either boat, but haver liked what I've tried of boat. I think the Ocoee would be a little snappier, and the Viper 12 a little faster and dryer. For me it'll come to whether I can find either boat used, and given that chance I wouldn't be too choosey about it. I'm going to try the Viper 11 a bit too, but I think it's too wet for me to own.
Good luck, PY.
Louie,
JM,
Good luck, PY.
