What kind of pumps do you use?
squidyaker
Post by squidyaker »
I was wondering what kind of pumps ya'll use. Electric vs. hand pump or what? I used a hand pump the other day and it sucks when your in a sketchy eddy.
I would appreciate websites, pictures, or any other suggestions. Thanks
chriscanoe
Post by chriscanoe »
I was wondering the same thing. I have been openboating for 20 years and never heard, or thought of this. Someone please enlighten us!
PBR ME ASAP!!
I''m just starting to mess around with a handpump. The outfitting in my boats does not leave much room to swing a bailer unless I park by the bank, in which case I might as well dump the boat.
I found the hand pump cleared water pretty well. But I need to find a way to tie the pump tube in place against the foam saddle, with the bottom end where most water is to be found, and the top end leaning some where it is convenient to work the handle when I'm not paddling. I still need to pick up some Tygon extension tubing at the hardware store for the pump discharge.
So, I'm not much farther than you on the issue, but maybe this will help. :roll:
dirk
electric pump
Post by dirk »
I used the following to build a system for my boat. Very clear and easy to follow directions. I decided to modify it as a single pump system and am very happy with it. Saves lots of time pumping or dumping when playing. I put the battery and switch in front and the pump right behind the saddle.
Do a search and you will find lots of other comments on the subject.
http://www.riverjunkies.net/howto/openb ... system.pdf
Austin, TX
OC1
Walsh
Swedish-made?
Post by Walsh »
That kind of thing's not my bag, baby.
FURZTROCKEN!
Louie
Post by Louie »
OK you all with a lot of hard work, ridicule, and some of his run on video during ALF we pretty much have Foton off of here. This is the very kind of post that will bring him back with a venagences
yarnellboat
Post by yarnellboat »
I don't have room for a scoop-bailer, and I don't want to mess with a battery system, so that leaves me with a kayaking hand pump, which I've recently decided to try, haven't tried it yet.
Probably won't set it up for on-the-fly pumping, but will just use in eddies while playing. While river-running, I don't mind dumping it on the bank occasionally, my legs always need the break anyway.
So, a hand pump seems like it would get me the main use for the least hassle.
PY.
This worked for me :
http://picasaweb.google.com/scott.broam ... 6880664290
http://picasaweb.google.com/scott.broam ... 4060533490
I put the same pump in my Fly, but had to shorten it (ran it vertical) - you can see the hole here :
http://picasaweb.google.com/scott.broam ... 7730277474
However, I caught the handle when rolling recently and wrecked the pump. I'm going heretic next and putting in an electric pump. To paraphrase the Warsteiner slogan, life is too short to spend it bailing. Or swimming.
C1NCR
try this
Post by C1NCR »
I use this system in both my boats. A bit pricey but I did not have to run around buing the bits, didn't have to figure it out, is simple and easy to transfer to a new boat and is VERY EFFECTIVE. I can empty my Phantom from full to the gunnels to almost dry in about 3 mins.
http://rapidrunnerbilge.com/products.php
virob
electric
Post by virob »
I'm new to open boating, but it didn't take me long to install an electric pump. Just about any of those electric bilge pumps in the 800-1000gph range should work fine, battery, wire, switch and case. Simple. Now when I fill up the boat surfing that wave or hole, I don't have to go find that "good" eddy to dump my boat.
cmnypny
Re: electric pump
Post by cmnypny »
dirk wrote:I used the following to build a system for my boat. Very clear and easy to follow directions. I decided to modify it as a single pump system and am very happy with it. Saves lots of time pumping or dumping when playing. I put the battery and switch in front and the pump right behind the saddle.
Holy crap ... Glad someone actually used my howto to build a system
Some of the cheaper 800 gph pumps have a higher amperage use so take that into consideration when selecting a pump
There was a whole thread on the board when I initially wrote the howto and asked people for a review
jim gross
HAHAHA
Post by jim gross »
Personaly I like a nice strappy sandle, maybe a stiletto spiked 4" heel with metalic tips that clippidy clop when she walks. Or some kick butt thigh boots.
Jim :0
ckingoc1
Post by ckingoc1 »
I have three boats with electric pumps, no two the same. And I get a lot of dirty looks from Louie :P I gotta say though if you have one better plan on it failing on you sometime ( probably when you're full to the gunnels) so don't forget how to dump or paddle with a boat full of water. :wink:
squidyaker
Awesome Dirk, just what I was looking for. I'll let you know how mine turns out when I finish it.
cmnypny
Post by cmnypny »
Here is the original post I was talking about earlier
http://www.cboats.net/cforum/viewtopic.php?t=7957859
