Moderators: kenneth , sbroam , TheKrikkitWars , Mike W. , Sir Adam , KNeal , PAC , adamin
Dale Barton
Posts: 34 Joined: Sat Apr 19, 2008 12:00 am
Post
by Dale Barton » Thu Mar 11, 2010 10:22 pm
Taureau has split along left seam from cockpit to stern, almost exactly like older glass boats would seperate topdeck from hull if there was seam failure. Any suggestions on a fix? Dale
Eric Nyre
Posts: 170 Joined: Mon May 14, 2007 2:37 am
Post
by Eric Nyre » Thu Mar 11, 2010 11:47 pm
Your local butt boat shop should have or know where you can find a plastic welder.
The Taureau is linear poly, very easy to weld. The welder can re-do the seam and you'll be good as new.
Louie
Post
by Louie » Fri Mar 12, 2010 1:10 pm
Here in East Tennessee, cumknock , Bob, swimmin Mexican and I all have plastic welders. Teaurea is one of the easiest boats to weld I've ever done.
