Claw like hands sensation
Anyone ever get the sensation of your hands seizing up during/after a lengthy, or not so lengthy, paddle?
During the last few miles of flat water of the LG Saturday, my hands, especially my t-grip holding one (left), got real painful and it felt that they were seizing up with what...arthritis (?)
After a few minutes trying to shake that clenching feeling out and taking a very relaxed grip I was on my way again.
I don't think I was gripping too tightly to begin with, but maybe I was?
Big Al
Big Al
I noticed that when I grip really tight on my paddle, it wears me out quickly and I sometimes cramp up. Except i cramp up in the forearms. It sometimes happens when I get in survival mode and paddle really hard. Relaxing a bit seems to help.
Team Blackfly
- markzak
So I've been thinking about something similar recently. In kayak instruction, kayakers are taught to have one hand locked on the paddle, usually their right hand, and have one hand less tightly gripped, which allows you to feather the paddle in one hand while maintaining a solid grip at all time.
With my Canoe paddles, I find that my shaft hand is the "locked" hand. When paddling, the shaft hand is 100% solid. My T-grip hand is flexible and I allow myself to have some give when grabbing the T-grip. I don't hold my T-grip that strongly.
Occasionally, in those beatdown times, the paddle gets ripped from my T-grip and I have to find that T-grip again to roll up. My technique is to run my left (t-grip) hand to the shaft where my right (shaft) hand is solid, then work my T-grip hand up the shaft to the T-grip again.
This also means that if/when/never/occasionally/not this year/OK a few times this year/ I have to pull my skirt and swim. I hold my paddle in my right hand (shaft) hand and pull my skirt with my left hand (T-grip hand). And I never let go of my paddle.
So I ask you AL and other lurkers, is your shaft hand solid on the paddle? Or you do you try to give hold your T-grip with unrelenting strength?
I do not have the issues you speak of, in my opinion, because i keep a relatively loose grip on my T-grip. I could understand though, why a lefty paddler with a more confident right hand would try to hold the T-grip for all life and not have a bomber hold on the shaft.
I've had that happen towards the end of a run or when I've been nervous. Usually the shaft hand, though. Remembering to loosen the grip and flex has taken care of that. Bananas are good, too.
I get it in my shaft forearm, usually on a long day, but sometimes it appears on short runs. It usually first appears on eddy turns or peelouts - duffek-ish moves where I'm really hanging off the paddle...mega forearm cramps, difficult to unclench the shaft hand. The dreaded Scepter Hand...
- Al Donaldson
Potassium and...
Big Al (as opposed to myself, who might be termed "Somewhat Lesser than Big Al)...
I'll not ask your age, but I (much older than dirt --in fact, I was on the design team for dirt) have found that, as I got older, the balance between various electrolytes (Potassium, salt, etc.) and blood sugar became critical in avoiding hand and leg cramps.
You can test this pretty easily: eat a candy bar before paddling and watch for the cramps: if they come on early or strongly, then you've got the old imbalance!
I discovered this a while back when driving long distances, with almost no pressure on the hands -- just the elevated hand position, along with a sugar load, was enough to do it. Dropping the sugar intake and elevating the electrolytes eliminates the problem for me. (No indications of diabetes, just a simple, possibly age-related imbalance.)
HTH
al
HTH
al
Al Donaldson
1920 Belle Avenue
Cedar Falls, IA
50613
(319) 277-3194
1920 Belle Avenue
Cedar Falls, IA
50613
(319) 277-3194
BA,
I have experienced your same "affliction". Sometimes the top hand and sometimes the shaft hand. I think that it is a result of too much concentration on the river and not enough focus on the fun. I usually can "shake it out" and go on without a problem, once I realize the need to relaxe! Cold water and/or cold weather ARE the obvious factor!
This only seems to be a problem (for me), during Spring and Fall outings. Gloves help, though they too, may tire your hands until you have adjusted. My advise, dress for the day and RELAXE!!!
LEW
LEW
cramps
al --
Thanks for the advice. Yes, old age may be a factor, if not in mind... probably in body.
I rarely eat candy bars n usually have a pb&j or 2, apple, and some trail mix or granola bar while on the river along with gatorade in my bottle.
What do others out there usually eat/drink on the river? Is this a new thread?
Then comes the Golden Monkies, of course, and that's a legendary shuttle story.
More bananas it is, I guess.
Big Al
Big Al
What are these Golden Monkeys you speak of.
Team Blackfly
