What type of pogies
What type of pogies
Just wondering What types of pogies you prefer.
Richard Guin
Lazy good for nothing slacker
My homemade 1/8" neoprene design. As long as your handle isn't too large, they will stretch over it and still seal enough of the shaft so that the lower hand stays fairly dry. And in my C1, my hand dips into the water a lot!
http://www.wwslalom.net/pogies
I have the same kind. Usually I go ahead and put both pogges on but slide the T-grip one down because my hand is hot. Matt's right though most of the time you could just use the shaft one and be happy (so if you see a kayak paddle with some....). But after a swim or on a really cold day it’s nice to be able to warm both hands.Todhunter wrote:I think mine are snapdragon? I only use the shaft one - the top one is annoying. With a dry suit, you'd be surprised how warm your t-grip hand stays.
I trained in Durango CO(high alpine, really cold), all last winter, and I can safely say that for control, the best thing out there is a ton of wax on the shaft. aside from that, I hate pogies. and usually just let my hand go numb. pogies can work, but I never thought they did much for me, so I just let them go all together.
i've seen a nice looking pair of kokatat or NRS ones that are made of gore-tex though... that would be something to look into...
cheers
-ids
cheers
-ids
- Mike W.
Bob's pogies ROCK!Bob P wrote:My homemade 1/8" neoprene design. As long as your handle isn't too large, they will stretch over it and still seal enough of the shaft so that the lower hand stays fairly dry. And in my C1, my hand dips into the water a lot!
That said, I did modify his design to make it easier to get the top hand in & out. I widened the top, which allows water in when you roll. Then I made a 45 degree cut, enlarging the shaft hole to allow that water to drain (if that hole isn't quite big enough, stick out your thumb to open it & drain the water from your roll). If you stay upright, they're just about as warm as before the mods (your hand will still sweat in moderately cold temps). As stated above, if it's not real cold I'll just use the one on the shaft.
Also, make sure to make them long enough to come up, over the cuff on your drysuit.
- ohioboater
neoprene gloves
I started out using a pair of c-specific pogies, maybe Mountain Surf brand - can't remember. Nice and warm, but the T-grip mitt is awkward to get your hand back into. It's also awkward to try to hold the t-grip without putting your hand back in. I discovered this in the middle of a shallow rapid when my blade caught a rock on the downstream side, and I had to let go of the t-grip in a hurry to avoid getting flipped.
I now use a set of 1/8" neoprene gloves. They work just fine for open boating, where your hands seldom get submerged. Might not be quite so warm for the bottom hand in a C1...
