Question about the Little in the Smokies
kimmieOC1
Post by kimmieOC1 »
Can anyone tell me what's the lowest level on the Townsend gauge that the Sinks to Elbow section can be run and still have Class IIIish fun?
Smurfwarrior
Post by Smurfwarrior »
Darn, I thought you were talking of these.. :)
http://gomeat.com/products/lit-l-smokie ... source=goo
ckingoc1
Post by ckingoc1 »
I think the lowest that I ran the sinks was 2.2ish. We ran down just past the Elbow. Thats also the the only time I've ran the Elbow.
But I've been told you can run it lower if you putin below the sinks.
kimmieOC1
Post by kimmieOC1 »
HaHa smurf :lol: .
Chris, I'm thinking I've been on it down to 1.9 and it was still fun, but I'm not really sure that was the level, so I'm trying to confirm.
cheajack
Post by cheajack »
As you know the gauge at Townsend is well downstream. You should also check rainfall gauges in upstream areas; New Found Gap and Mt. LeConte for example..
oopsiflipped
Post by oopsiflipped »
depends on if it is going up or down b/c gauge has quite some time delay. 2.4 is pretty hard on your boat. 2.6 is starting to pad out.
pyc1
Post by pyc1 »
2.6 is a reasonable minimum. Lower only if you enjoy hitting rocks.
