Saddle placement on a viper 11
oc1matt
Post by oc1matt » Thu Dec 30, 2010 4:34 am
Hey guys nice site. I have a question about the best placement for the saddle on a viper 11. My girlfriend bought me a used vioer but it didn't have any outfitting, so I'm putting it in now. It's a north wood saddle. I've read that you eeant your hip bones to be exactly at the center of the boat when you are sitting vertical, is this accurate?
Thanks and sorry for any typos I'm using my gf's iPad (her present :D)
Matt
Searching far and wide for whitewater in Texas
fleckbass
Post by fleckbass » Thu Dec 30, 2010 3:26 pm
Some may comment on different ways to determine this. you may want to look at Mohawkcanoes.com. There are measurements for this.
fleckbass
Post by fleckbass » Thu Dec 30, 2010 3:35 pm
http://mohawkcanoes.com/outfit_saddle.html
You can verify this by putting the boat on a 2X4, balancing it at mid point (right on the H in "Mohawk") and getting in. A little bow light is probably OK but you should be able to get the bow down when leaning forward a bit. Hope this helps.
fleckbass
Post by fleckbass » Thu Dec 30, 2010 3:39 pm
Oh, I see you have a different saddle. Measurements may not apply but 2X4 technique may help.
Mr.DeadLegs
Post by Mr.DeadLegs » Thu Dec 30, 2010 3:46 pm
Is this a wood and cane seat or a minicell type saddle? I went to the North woods site and see no WW saddles.
fleckbass
Post by fleckbass » Thu Dec 30, 2010 3:46 pm
milkman
Post by milkman » Thu Dec 30, 2010 4:04 pm
One rule of thumb is to have the seat back (where your back contacts the seat) 7 to 7.5 inches from the center of the boat. To do that, you draw a line at the center of the boat (center from bow to stern), and position the seat so that the seat back is 7 to 7.5 inches from that line towards the stern. With the seat in position, draw around its outline to mark that position. Then go to a still body of water (a pool is great) and get in the boat, position the seat within the outline you drew, sit upright on the seat in the standard kneeling position, and have someone on shore check the boat's trim. Bow and stern should be about the same in where they emerge from the water. Some folks like their boat to be a little bow light, but be careful not to make it too much ... it should just be enough that you can notice it and no more. While you're in the boat, you can move the seat a little fore and aft and have the person on shore report on how the movement changes trim. You might even have them take pictures with a digital camera so you can look as well. When you have the seat where you want it, make final marks.
oc1matt
Post by oc1matt » Thu Dec 30, 2010 4:33 pm
Sorry I meant north waters, must have drank too much nog. This saddle http://www.northwater.com/html/products ... addle.html
So I'll try to do the 2x4 test and get that kind of balance. I'm using shore adhesive hopefully that will work. Out of curiosity when people talked about making their thwarts an inch shorter, is that an inch shorter in relation to the standard width of the boat? Because where you put the thwarts would change the length or am i missing something.
Matt
fleckbass
Post by fleckbass » Thu Dec 30, 2010 5:18 pm
They are shortining the thwarts to pull in the sides of the boat to increase performance. I haven't experimented with this yet. Just bought a Probe 11 with adjustable thwarts.
Cheeks
Post by Cheeks » Thu Dec 30, 2010 5:19 pm
I used shore adhesive to glue my saddle together, but I can't speak to its effectiveness adhering minicell to vinyl.
Just be careful when you use it, it is nasty stuff.
Even with a respirator, after twenty minutes working with this stuff, I started having all sorts of crazy hallucinations about becoming a professional whitewater canoeist...
Chris Loomis a.k.a. Cheeks
I've been known to canoe at times
Mr.DeadLegs
Post by Mr.DeadLegs » Thu Dec 30, 2010 6:06 pm
Changing the thwarts will change the boat in many ways. Pulling them in will reduce rocker but may increase speed, it may change how flat the bottom is, and how sharp the chine is. If you find after pulling the boat in that you need more initial stability try going wider, if the boat feels a little sluggish pull em in.
Einar
Minicell to vynll
Post by Einar » Fri Dec 31, 2010 5:05 am
I use a product called Sikaflex to bond minicell to vynll or glass. Works very well and is removable if you want to readjust. It is marine adhesive/selant, buy the long cure type (24 hr)
jakke
Post by jakke » Mon Jan 03, 2011 9:22 am
It also depends on the saddle type: straps or bulkhead. I've a bulkhead in my viper11, and it feels like a bit bow-heavy with the mohawk saddle placement. But then again, there is more weight in front of the saddle then there is with straps.
