BOOF Stroke
- Mr.DeadLegs
BOOF Stroke
What is the best way to get a good launch off a drop in a coal barge (12' boat)? Just speed, paddle stroke at lip, raising knees? What works and why?
- Dooleyoc-1
1. Speed coming in will make a big difference. 2. Grab the lip of the ledge drop or waterfall with your paddle. 3. Take a powerfule stroke and do a huge hip thrust to polevault yourself out and prepare to land flat. You can cheat in a big 12' canoe by turning the boat away from your onside with your boof stroke to land a little sideways at the bottom. That's a trick I use sometimes when I'm boofing the spark.
All you need to know said above by Dooley. You probably want to be sure your are in the outfitting pretty well or you won't be able to transmit your paddle stroke energy into moving the boat. Just like rolling, you are "grabbing" the lip of the drop, water, etc. to anchor yourself for the hip/body motion, which is the thrust or bow raise in this case.
http://vimeo.com/13661255
00:15 is decent, 00:48 is kind of poor, but both basically dry landings. Paddle stroke is early at 00:48, but the sloping nature of the drop combined with the boat length made it feel like the bow would already be going in if I got the actual lip of the rock. The length and bow volume of the long boat will take care of you as long as you have some success in keeping the bow up and projecting it out off of the drop so you don't just pencil.
I can't say I've ever successfully boofed -short boat or long - except where the rocks / water helped me out. However, I can definitely say that I've leaned back lots of times and it *never* helps. It's a reflex I'm working to overcome...
- doomroller
Depends, if you lean back coming off the drop it's generally trouble brewing. But if you lean back in the process of taking the boofstroke and then move forwards as your weight begins to move into the free space that's fine.sbroam wrote:I can't say I've ever successfully boofed -short boat or long - except where the rocks / water helped me out. However, I can definitely say that I've leaned back lots of times and it *never* helps. It's a reflex I'm working to overcome...
It's important that you don't just lean your weight forwards either, that's inviting a headplant. The "lean forward" should be more of a stomach crunch in which you actively use your abdominal muscles to bring your head and knees closer together.
If you don't mind taking class IV advice from a class II paddler who never boofs anything, here's my 2 cents....
I don't think of it as "speed" so much as timing or acceleration - the point isn't just how fast the boat is going, but more that you're active in paddling it at the time.
And, in addition to the leaning back, leaning/landing onto the brace seems to result in a lot of flips - it's obviously tempting to favour landing on our brace, but I think it's common for people to overdo that, and end up flipping to their on-side or needing a huge brace and swamping in the process. So for landing, I'd suggest trying to plan for another forward stroke and think less about a brace.
Pat.
Pat.
- markzak
I would add that the biggest mistake people learning to boof make is usually related to their actual stroke. The way people describe "grabbing the lip" of the drop is important. BUT, way more important than that is how you effectuate your stroke to grab the lip. Too many boaters don't get their paddle dead vertical and dont put their body weight into the paddle stroke. Putting your weight into the stroke prevents you from sweeping and prevents the boat from turning as your boof.
Its a complex stroke that comes with practice. You can practice in flatwater. Take a stroke with good form, keeping the paddle vertical and pull from as far forward as you can reasonably reach to your knees. Stop at your knees, if you pull back any further you're almost forcing yourself to lean back as you come off the boof. It doesnt have to be a fast quick stroke at all, just good form.
If you practice in flatwater and find that the boat is not going straight during this stroke, keep practicing. Before a really important boof, I will practice that stroke in the eddy over and over again until I feel confident with it, the timing, power, etc. then I peel out. I also support everyone else's advice so far.
- rockyboater
This link was from a couple years ago... and will work fine with a 12 footer.
A good bit of which has been mentioned.
http://cboats.net/cforum/viewtopic.php? ... c&start=11
