That all strokes done from the stern should be avoided like the plague. While this sentiment is grand, if the overall goal is speed. But is speed always the objective? We've all heard that speed kills, and many times the opposite to moving forward is good. In my (:roll:) opinion it's a lot easier to do, and often better to slow down. Gaining control can be gained by going slower than the flow.
I'm thinking...
For instance a good forward cross bow sweep is great, but when at the end of a stoke, you can be left on the wrong side. In this case sometimes a onside stern sweep would be nice, so that a immediate onside forward stroke is possible. Where it's really a situation of what's going to be your next move (and what's going to happen next). The delay in speed caused by doing a rear correction (at the proper moment) might also be an added welcome. For instance it might be in the plan for missing -that- rock, or gaining an eddy. Stern work is also mighty powerful, so there may be benefit's in conserving energy.
Another instance might be when a particular lean is required. I tend to think of leans in eight directions. In addition to left, and right, and front, and back, there are also the four diagonal leans. Which when used with a stern stroke can do a lot of good. Another time is when doing back ferry's. Where the stern component may be the major steering portion, or the setup stroke. I'm sure there are many more examples...
OK - tell me why I' wrong
