Silly conversion question
mccabekev
Post by mccabekev » Sat Sep 03, 2011 5:39 pm
Yes - I know this is a silly conversion question but here goes.
I know of the methods of using some form of large plastic tubing running between the front and rear pillars as a base for the saddle etc
But what methods are there for boats with no pillars (e.g. prijon)
What options are there (if any) short of drilling the hull in multiple places?
cheajack
Post by cheajack » Sat Sep 03, 2011 6:46 pm
make foam center walls.
griffen_williams
Prijon
Post by griffen_williams » Sat Sep 03, 2011 9:37 pm
The Prijon Rockit that i picked up from Scott Broam had a inner hull type plate that everything was mounted to and that was mounted with two bolts in original seat bolt holes.
GW
Smurfwarrior
Post by Smurfwarrior » Sat Sep 03, 2011 9:44 pm
I converted a pillarless eskimo Xeno and used a piece of wide flat plastic to attach the center rail (5x5 plastic fence post) to the front side mounting points where the footrail was made to attach. For the rear I simply built up foam on the top of the rail to engage the profile under the back deck of the cockpit. Worked well for me.
oopsiflipped
Post by oopsiflipped » Sat Sep 03, 2011 9:59 pm
i have some pics of my hercules i can send you if you like. i made some aluminum pieces that hold the center rail to the bulkhead and seat bolts. maybe not the best way, but other than having to replace some rivets here and there, it has held up well.
Smurfwarrior
Post by Smurfwarrior » Sun Sep 04, 2011 4:48 am
GW- how do you like the Prijon Rocket?
griffen_williams
Rockit
Post by griffen_williams » Sun Sep 04, 2011 2:18 pm
It pretty good. Very fast punches through just about anything. I got a Karnali a year ago and since then its really just sat around. Its a little roly poly, made my roll a lot faster though.
GW
