Spare paddle mounts - post some pics?
- ohioboater
I paddled with a guy a few weeks ago who had a pretty cool setup for holding his spare OC paddle: shock cord across the deck plate to hold the blade, and some sort of quick release on the thwart to hold the t-grip. Didn't occur to me at the time to look closely at how the thwart mount was set up, but I'm guessing someone on here has come up with a similar idea.
Anybody want to post a pic of their paddle keeper setup? Long boat, of course.
North Water sells a paddle anchor for this:
http://www.northwater.com/html/products ... nchor.html
Things like ski straps and Velcro power straps work too. In longer boats I just shove the blade under the deck, in my Ocoee there is bungee on top of the deck, as you describe.
P.
P.
thwart smart
The thwart smart is a good solution. Similar to the paddle anchor previously posted.
http://shop.scottcanoe.com/Thwart-Smart-00041-T.htm
I use "Bungee Dealy Bobs" for tying down all sorts of things. Would probably do the trick...
http://www.oldscoutoutdoorproducts.com/index.html
Ive got a bungy atatched to the forward deck plate, across so at to hold the blade and (depenting on outfitting) have either double sided velcro, or the esquif bungy outfitting for knee staps holding the Tee grip against the thwarts.
Of course for smaller boats I just have a Frank-N-Breakdown shoved inside under the bags.
Proud Yankee
- ohioboater
Velcro - duh
I've got a bunch of velcro and a sewing machine. Don't know why I didn't think of that sooner...
Back when I was a teenager in MO, I worked with a guy who used to carry a sawed off shotgun like that strapped to the inside of his canoe when paddling on Ozark float streams. Never understood why he needed it, other than the fact that he was a testosterone poisoned gun nut.sbroam wrote:
Maybe he thought Deliverance was a documentary? I have to admit I've considered similar when paddling back in the swamps around here that are populated with gators and hogs...
- ohioboater
good point
Or up in grizzly country, though a 12 ga might not do more than piss off a brown bear.sbroam wrote:I have to admit I've considered similar when paddling back in the swamps around here that are populated with gators and hogs...
Biggest threat on MO rivers like the Current is burned retinas from overweight, drunken rental customers exposing themselves.
Go to a police auction. Those are the racks that many agencies use to mount rifles and shotguns in cars. In addition to shotguns they make them for AR-15's, and M-14's. You could even wire them into your bilge pump's battery so the electric quick release button would work for those situations where the wascally wabbit is on the bank and you need to blast him now!
I have always just hung the spare paddle in the bag cage.
Kyle
Kyle
