Robson Homes PE
bushpaddler
Robson Homes PE
Post by bushpaddler »
News from Bavaria, no prices available yet, but at least some pictures...
TheKrikkitWars
Re: Robson Homes PE
Post by TheKrikkitWars »
Someone has clearly seen which way the wind is blowing...
PatrickOC1
Re: Robson Homes PE
Post by PatrickOC1 »
I see thigh straps :D any word on weight etc?
ian123
Re: Robson Homes PE
Post by ian123 »
Anyone paddle that design before?? It looks wet. Good for vertical move though?
Shep
Re: Robson Homes PE
Post by Shep »
ian123 wrote:Anyone paddle that design before?? It looks wet. Good for vertical move though?
It would be very interesting to put one side-by-side with a Prelude. Looks like they might be similar in the speed/dryness categories.
philcanoe
Re: Robson Homes PE
Post by philcanoe »
Have seen the Amerlite version, but never paddled.... always wanted a plastic one.
Looks really dry, and likely to have nice speed. I'm sure one of our European boaters will have worn one (or two) out by now. Believe this was the last Frankie boat, although never have substantiated that.
    ian123
    Re: Robson Homes PE
    Post by ian123 »
    Spanish fly paddlers think everything is dry :)
    philcanoe
    Re: Robson Homes PE
    Post by philcanoe »
    Simply because :wink: Spanish Fly paddlers ...
    ... can paddle most-every thing dry.
      ian123
      Re: Robson Homes PE
      Post by ian123 »
      True. I loved and hated my fly for that reason.
      PatrickOC1
      Re: Robson Homes PE
      Id say it looks real similar to a prelude well from those angles.....
      TNbound
      Re: Robson Homes PE
      Post by TNbound »
      That looks awesome (like a prelude with harder edges! What more could you want?), but I'm guessing it will be another robson boat we rarely see on this side of the ocean.
      It does look like it would fill the "slightly faster than the L'edge/Option" niche, though.
      -Anthony
      TNbound
      Re: Robson Homes PE
      Post by TNbound »
      PatrickOC1 wrote:I see thigh straps :D any word on weight etc?
      From the Robson site:
      length 296 cm
      width 70 cm
      height Bow 48 cm, Center 40 cm
      weight 24 kg
      volume 380 ltr.
      material PE-Superlinear
      capacity 120 kg
      -Anthony
      Todhunter
      Ridge Spirit Outfitting
      Re: Robson Homes PE
      Post by Todhunter »
      length 9' 8.5"
      width 27.5"
      height Bow 19", Center 15.75"
      weight 53 lbs
      volume 100 gallons
      capacity 265 lbs
      For us metrically challenged folks...
      Matt Todhunter
      avlclimber
      Re: Robson Homes PE
      Post by avlclimber »
      For us non-metric Americans:
      length 296 cm > 9' 8.5"
      width 70 cm > 2' 3.5" (27.5")
      height Bow 48 cm, Center 40 cm (18.8", 15.7")
      weight 24 kg > 52.9 lbs
      volume 380 ltr.
      capacity 120 kg > 264.5 lbs
      That is pretty awesome turn-around from the suggestion 4 days ago in this thread:
      https://cboats.net/cforum3/viewtopic.ph ... 2&start=15
      That's a sweet looking boat.
      philcanoe
      Re: Robson Homes PE
      Post by philcanoe »
      More feet for meters ====> viewtopic.php?f=2&t=7965837&start=13" onclick="window.open(this.href);return false;
      not copyrighted - from: Hydrocarbon Processing, 1981 April
