I know many of you have the Go Pro Hero cameras so I'm looking for a short cut to set mine up. Is there a particular resoution that's best for mounting on the bow or stern of a canoe? What about sticking the base to the boat as far as prep. I would think you would clean the area with alcohol. I will be using mostly video. Any other tips you can think of that would be helpful would be appreciated.
camera setup
Re: camera setup
Both my Heros came with a flat base. I just Duck-taped the flat base to the bow or stern deck, plus a safety line to the grab loop. With my HD version, I use the standard 16:9 aspect. I think that a stern installation gives a better perspective as to the nature of the water and the paddler.
Re: camera setup
If you are going to film, it is helpful to set it up so that it automatically starts shooting video as soon as you turn it on. That way there is just one button push to turn on and shoot or turn it off. The instructions explain how to do this from the setup menu.
Another thing I've found is if you let the battery die, the video being shot when the battery dies can get corrupted.
It AIN'T bent.
Re: camera setup
not a deck mount but cool...
http://www.youtube.com/watch?v=I4hghtTy ... ture=share" onclick="window.open(this.href);return false;
Re: camera setup
Craig, that is really cool, I really like the way it films the entire paddler, not just his hands and bow of the boat... Thank you for sharing!!
Cheers
Cheers
Re: camera setup
That taller stick mount gives a great perspective.
