Paddle Grip
Dave.E
Paddle Grip
Post by Dave.E » Tue Jul 31, 2012 6:38 pm
Does anyone have any suggestions to add some grip to a paddle shaft? I tried some climbing tape but all the sticky eventually started coming through.
Dave
woro90
Re: Paddle Grip
Post by woro90 » Tue Jul 31, 2012 6:57 pm
What kind of a grip? For bare hands? For gloves? How much of a grip? I wouldn't cover my paddle with sand as I like to slide my lower hand along the shaft according to what I need to do, sometimes mid-stroke. I understand that this is exactly what you don't want, do you?
Paddle solo, sleep tandem.
Shep
Re: Paddle Grip
Post by Shep » Tue Jul 31, 2012 6:58 pm
There was a long thread a while back on this. The stretchy-style electricians tape seemed to be favored by many, although that thread was about reducing shaft-wear, if I remember correctly.
woro90
Re: Paddle Grip
Post by woro90 » Tue Jul 31, 2012 7:03 pm
Dave.E
Re: Paddle Grip
Post by Dave.E » Tue Jul 31, 2012 7:17 pm
For gloves and bare hands.
Just looking something to leave on the shaft so its not all slippery. I had some climbing tape on it but the water made the sticky come through and would gum up my hands which I didn't like. I tried hockey tape and the same happened.
Dave
busterblue
Re: Paddle Grip
Post by busterblue » Tue Jul 31, 2012 7:28 pm
I think this was the post that Shep referred do:
viewtopic.php?p=85250
I've been using the foamy-grip stuff that's made for bicycle handlebars. A little electrical tape at the top and bottom prevents it from unraveling. I initially used it for gription when wearing gloves. But now I use it all the time. The downside is that it's not very durable. I just wrap up about a 6-inch area--where my hand is 95% of the time. It doesn't stop me from changing my grip when needed. If you wrap too low, it will wear off against the gunnels.
fez
Re: Paddle Grip
Post by fez » Tue Jul 31, 2012 7:59 pm
brush some epoxy on the shaft and put some fine powder (filler) or fine sand on it
imagine
watermonkey
Re: Paddle Grip
Post by watermonkey » Tue Jul 31, 2012 8:55 pm
Paddle wax.
bkebs
Re: Paddle Grip
Post by bkebs » Tue Jul 31, 2012 9:09 pm
I put electrical tape wraps 3 inches apart on the shaft. It has worked well for a month. I used to be annoyed by my hand slipping on the shaft, but this has solved the issue for me.
kaz
Re: Paddle Grip
Post by kaz » Tue Jul 31, 2012 9:35 pm
100 grit sandpaper, AND, de-grease your hands with river mud before paddling.
JKaz......
Re: Paddle Grip
Post by Larry Horne » Wed Aug 01, 2012 3:21 am
surfboard wax works great
ian123
Re: Paddle Grip
Post by ian123 » Wed Aug 01, 2012 4:53 pm
I ve used cross country ski wax. It's grippy but it comes off and will make your gunnels black and sticky.
I find i only slip when I wear mitts. A short wrap of duct tape of gorilla tape helps. Take it off in the spring so your hands don't get sticky.
Bill M
Re: Paddle Grip
Post by Bill M » Wed Aug 01, 2012 5:35 pm
What Kaz said. My go to paddle has a dynel,I think, sleeve on the bottom half of the shaft. It seems to collect body oil, sun block etc so I also wash it with sand dirt. My bare wood shaft is much less slick.
Bill
Re: Paddle Grip
Post by Bob P » Thu Aug 02, 2012 12:29 pm
Interesting... My lower hand never grips the shaft tightly. Having the shaft "sticky" would drive me crazy.
Todhunter
Ridge Spirit Outfitting
Re: Paddle Grip
Post by Todhunter » Thu Aug 02, 2012 12:49 pm
Like Larry said, I use Sex Wax on my shaft. :P
Matt Todhunter
