Looking good!
You'll have quite the setup when you're done.
a bit off topic winter project
Re: a bit off topic winter project
Cut it out.
I'm starting to feel lazy and unimaginative. Think I'll take a nap to get over it.
e
e
working on the canopy held open with a tensioned cantilever added to the outer hoop. buckminster fuller would approve. for music we added speakers with a very small amp and spring loaded fold away solar panel to trickle charge the battery all day. starting to paint after using spray foam on all the seams inside and some rot on the top. all the diamond plate is in the fab shop being cut and will be rivited to the body. for now i will use a small insta tent on the trailer and tarps. if it rolls good and the woman is into it i may have to make a true tent for the frame.
got the body done.
Nice work Harry. Fun project!
