C1 Remix conversion
bearboater
Re: C1 Remix conversion
Post by bearboater » Fri Dec 18, 2015 6:09 pm
Interesting double strap method, curious why not a bulkhead with single strap set up?
Do you plan to use the boat for extended trips?
Prost
-Isaac
Pea Pod
Post by Pea Pod » Fri Dec 18, 2015 8:32 pm
It is my first conversion and the absence of a bulkhead seemed like a good way to keep the space under the bow deck easily accessible for trips.
bearboater
Post by bearboater » Fri Dec 18, 2015 8:49 pm
[quote="Pea Pod"]It is my first conversion and the absence of a bulkhead seemed like a good way to keep the space under the bow deck easily accessible for trips.[/quote]
Nice, Yeah it certainly gives that advantage. I've had set ups previously with the bulkhead fit in with force-to allow ease of access to storage. Both ways work, always just curious about others configurations.
Prost
-Isaac
Just saw your avatar, is that the bottom bridge at Penrith?
Pea Pod
Post by Pea Pod » Sat Dec 19, 2015 1:43 am
I'd like to see one of those bulkhead conversions in the flesh. Prior to this, I've only paddled OCs with bulkheads.
An attraction for using kneestraps over a bulkhead is the adjustability. Plus, the kneestraps maintain their shape so that the paddler can slide their knees in, upon entering the boat, just like a bulkhead.
Kneestraps meant drilling two holes in the hull, but i'm yet to see a downside to that, despite the theoretical undesirability.
Post by Paddle Power » Mon Dec 21, 2015 1:33 am
I really like the adjustable seat/saddle set up, super sweet!
Post by sbroam » Fri Jan 08, 2016 7:03 pm
Starting about here is a series of pictures from my Remix conversion with snow board knee straps and a snap shackle based quick release. it evolved from the original install sitting on a PE plate held in place by friction and pressure with no bolts - I relented and did drill some holes :-) Of my various conversions, this is the one I'm happiest with. Secure enough to play, adjustable, yet no exit anxiety. I have a variation of this in my playboat - bulkhead + straps with a snapshackle.
https://picasaweb.google.com/1038689084 ... 9579966690" onclick="window.open(this.href);return false;
