C1 conversions and airplane buckle releases
Pea Pod
Post by Pea Pod »
In my C1 conversions, I have found inconsistencies in airplane buckles and the tab release. I have a good pair that release with only a small lift of the hinged tap, and another pair that I won’t install because they require opening the tab nearly 90 degrees. I bought both pairs from an ebay seller.
Does anyone know a good brand or seller?
Ianonetwothree
Re: C1 conversions and airplane buckle releases
Post by Ianonetwothree »
Strap works ? I can't say that they re any different then what you have. What difference does it make if you have to open them to 90 to get them to release?
Pea Pod
Post by Pea Pod »
I like a quicker release. Especially good when things are turbulent and I want air.
