C1 Conversion
barlaz
C1 Conversion
Post by barlaz »
Has anyone had experience with the C! conversion kit from Jackson?
1. The pictures suggest that you need a release a rope on the backband to wet exit. This seems like more than I might want to worry about in a wet exit. Any experience?
2. I am intersted in a Jackson Zen.
If it were a kayak, then I would order a medium. Is there a reason to go up a size because my center of gravity is higher.
Mort
Raleigh NC
Ra;eigh, NC
ClassFive Boats
Re: C1 Conversion
Post by ClassFive Boats »
Call Bernie at whitewater warehouse , he can tell you all about the jackson/ c1 kit since he sells and uses them
No , wet exits are easy from this kit.
I would pick my boat size based on paddler weight only, not on k1 or c1 use.
Cheers
