Cascade question
Cascade question
Picked up a fairly new cascade but the seat foam is missing . It has the backrest foam that is 3 inches thick . I want to set it up completely stock. Was the seat foam in the original cascades also 3 inches thick? Thanks
- Mike W.
Re: Cascade question
Is been a while, but 3" seems about right for thickness. Taller than stock will help keep you in the straps better when you roll.
