Greetings,
I've been paddling a detonator, a great hull, for two years and I'm looking to switch to bulkhead outfitting - the straps loosen up far too quickly with water in the boat and therefore the boat doesn't feel solid in must move situations. Any good aftermarket saddles out there for this conversion? Esquif's website draws a blank on this one. Do I need to get some ash for another thwart and a minicell bun and craft my own?
Thanks!
Esquif Detonator: Bulkhead outfitting conversion
- Smurfwarrior
First thing- you posted this in the wrong section (vids). It needs to go in the main forum so people can find it.
Second- just add a thwart and foam in front of your saddle to build that up into a bulkhead. Check the top of the forum page and you'll find Craigs website Under "outfitting" where he lays it all out. Best of luck!
