ABS Royalex repair
New to CBoating? Look here for loaner boats, demo boats, free boats, instruction, and other folks in your area to help you out. Do NOT post questions here - those should be posted in the main CForum.
MaureenL
ABS Royalex repair
Post by MaureenL »
Hello:
New to whitewater canoeing and picked up a Dagger Dimension that needs some repair. I think I am pretty clear on the process with the ABS and acetone but am wondering how warm it should be to attempt the repair. My directions say warm and dry conditions without any specifics.
thanks,
Maureen
Re: ABS Royalex repair
Post by Paddle Power »
as in above or below freezing?
I'd say the warm the better, i.e. room temperature or in the sun would be good.
MaureenL
Post by MaureenL »
Thanks, I will go for room temperature or above.
Maureen
mahyongg
Post by mahyongg »
warm is good, but you want to have it so that the acetone doesnt immediately evaporate, but has some time to soften the underlying ABS as well..
Work in thin layers - then it will evaporate very fast! But it also won't evaporate on the surface first, making it harder for the underlying acetone to escape, like in a thick application... which you don't want, because this could create new problems.
Cheers!
Jan
